Rapid battery drain - ammeter and oil press red lights on
Old Jul 13, 2019 | 01:08 PM
xk8newbie's Avatar
Default Rapid battery drain - ammeter and oil press red lights on
light on with ignition switch off and key out
1. new battery within last year
2. battery discharges within 5-6 hours after charging
3. red warning light on on ammeter and oil press when key is not in ignition
Saw some threads about bad ignition switches - mine seems to click through each position well
Any wisdom?????
Old Jul 13, 2019 | 01:17 PM
Johnken's Avatar
Key out, drivers door open, does chime sound (like you left keys in ignition)? Oftentimes the flap that covers key hole gets stuck up. Car thinks keys in ignition, battery drains. Happened to me last week.
This is 1 of many possibilities, just getting things evaluated and eliminated with you.
John
Old Jul 13, 2019 | 01:22 PM
xk8newbie's Avatar
Apologize for not being more thorough before posting. Double checked the positive and negative terminals of the battery - all I did was touch the negative braid that is grounded to the frame and the trunk lights came on - not sure if it is the battery side or frame attach point but will be removing and cleaning both.
Old Jul 14, 2019 | 07:26 PM
Johnken's Avatar
Thata ok, glad you found it. Btw, thanks for the follow up to close this out. Its always nice to know someone solved the problem and how they did it.
John
Old Jul 15, 2019 | 02:06 AM
DavidYau's Avatar
Best still check the battery drain - should be about approx. 150mA - when car is asleep which typically takes 15min - you need the trunk open to check it.
Some Day, Some Day
Jul 14, 2018 09:15 AM
Ophitoxaemia
Apr 28, 2018 09:44 PM
JBGROSS
Nov 30, 2016 06:24 PM
CraigNelson
E type ( XK-E )
Jul 31, 2015 12:22 AM
statfunk
Apr 21, 2015 03:52 AM
