Rattle Pop From Above
Old Sep 10, 2013 | 06:50 PM
Mike Graham's Avatar
Question Rattle Pop From Above
Hi All,
I have a rattle and popping sound coming from the center visor header. I am sure it isn't the visor/vanity. It is coming from inside the header panel where the courtesy lights are mounted. I am assuming that it is the hydraulic lines vibrating on something. So I want to pull it down and put some foam in there to stop it. It is just enough to get on your nerves. I read something about removing the A pillar covers and it exposes some screws and that there is a couple more at the ends under the weatherstrip. I cant see any screws under the weatherstrip. Is there any instructions on how to pull this thing off and the A pillar covers as well so I can get to the rattle.
Old Sep 11, 2013 | 06:59 AM
JSC's Avatar
JSC
Mike, you can pull the A-pillar covers off. There are no screws to remove first. The header panel also has no screws. Once you remove the visors and clips, the complete liner should come off. It is not complicated at all. I belive the later models have speakers in the A-pillar, but mine doesn't.
Do a search on the forum. (and Youtube!) It is all here.
Hope you get it!
Dutch xjrdiamond
Nov 30, 2019 09:14 PM
redxk8
Oct 4, 2015 08:28 AM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
millertic
Sep 30, 2015 08:11 PM
