Re windows
Old May 26, 2020 | 06:38 PM
Dave01's Avatar
Default Re windows
Is it possible to disable the passenger and drivers windows from doing the opening and final closing when the doors are opened and closed.
I have tried resetting them but they both keep going down
Old May 26, 2020 | 06:42 PM
MattArnold's Avatar
if you do this, either the window won't close properly and the car will leak because the window is down, or the window will break when you slam the door.
Old May 26, 2020 | 07:21 PM
Dave01's Avatar
I would like to think that i could operate windows to open and close them from the control buttons inside
Old May 26, 2020 | 07:43 PM
MattArnold's Avatar
You can operate the windows from the switches inside the car to open and close.The dropping of the window when you open the door is an auto function to protect the glass on the door. Or do you mean something else? I seem confused then.
Old May 26, 2020 | 07:53 PM
Dave01's Avatar
No you are correct in what you say think i will have to keep resetting windows hopefully they will come right
Many thanks for your advice
Old May 26, 2020 | 08:08 PM
mhminnich's Avatar
When the windows frequently lose their memory setting, that generally means it's time to get a fresh battery in your car.
As many members on this forum will attest, window memory function is one of the first signs of a failing battery.
Old May 26, 2020 | 08:47 PM
DavidYau's Avatar
+1 to mhminnich and all the suggestions above. Failing windows up/down on door opening is a classic sign of Low Battery Charge.
A good battery should hold approx 12.8V and if it drops below that all sorts of warning messages can come up on the dash when you start the car. If I haven't driven the car in a few days, some of my other signs are:
1. TRAC Control
2. DSC
3. Low Brake Fluid
4. Check Engine Light
etc
Either give the car battery a good overnight charge and/or get it tested at any local garage/store who should do it for free.
Old May 26, 2020 | 09:11 PM
Dave01's Avatar
1. TRAC Control
2. DSC
3. Low Brake Fluid
etc
Thanks for that
I don't get any other warning lights so i will give it a good charge and see what happens
Old May 27, 2020 | 03:58 AM
bladerunner919's Avatar
What about when you are out of the car? And to get in and out you'd have to drop the window enough not to risk it breaking, and then raise it again to stop it leaking.
DatDude
Sep 24, 2014 01:29 AM
Edv468
Feb 21, 2014 02:31 PM
Getghost
Sep 3, 2012 08:50 PM
EdinVA
Jul 28, 2011 10:26 PM
Skid Mark
Sep 3, 2010 09:54 PM
