Rear 1/4 Window Regulator
Old Oct 31, 2009 | 01:21 PM
Robscountach's Avatar
THANKS TO EVERYONE !
I was able to remove the unit from the top (lots of prying). Then, I pulled the assembly apart, re-strung the unit, and re-installed (lots of prying, contortions, and rubber hammering).
I noticed the extra, useless strip of metal on the bottom of the regulator to keep it from bending, was bent itself...nice. Obviously the bottom tail of the unit flexes and pulls the cable off the wheel.
I fixed this, but installing a stud in the regulator that rests against the inner-body, so when it tries to flex, it can not.
Not bad a fix. Just cost me a few hours of time and .50 at hardware store !
Old Nov 1, 2009 | 01:20 AM
H20boy's Avatar
nice job rob!
Old Nov 1, 2009 | 05:23 PM
GreenJewel's Avatar
Glad to hear your got it fixed.
Old Jan 31, 2011 | 02:22 AM
jagosaurus's Avatar
Great work, I have the exact same problem, could you describe how you attached the stud to the regulator? Paint.exe?
Old Oct 12, 2011 | 07:33 AM
Glenn Barickman's Avatar
I replaced my and usrd this link. Did not have to remove the top.
https://www.jaguarforums.com/forum/a...eplacement-pdf
Old Oct 12, 2011 | 07:53 AM
  #28
K.Westra's Avatar
I just brought my car to the shop for this problem. There is a TSB (501-49) for my car that probably never got done, so the car is probably getting new regulators and both windows will finally get adjusted properly. Normally, I'd do this myself, but it sure seems like a long process and I don't have the time right now. If the window weren't stuck down, I'd wait for the spring.
Old Oct 12, 2011 | 08:04 AM
Gus's Avatar
Gus
Great job!
Old Mar 14, 2023 | 06:33 PM
  #30
Dawn Caputo's Avatar
Default I’m wondering the same thing!
I am at the same place except in replacing the entire window regulator. I have the new one but can’t find a way to get it out! So frustrating!!!
Originally Posted by Robscountach
Hey,
Sure, it can't hurt; Thanks.
Yeah, I haven't seen too many posts about tearing into their car here (except for the top's hydraulic lines). Its just that I'm pretty sure I can repair this regulator by reinforcing the track...and save A LOT of money. It shouldn't be that difficult, but need to know how ~ once I get the unit re-assembled ~ how to get it back.
I can tear it apart and reassemble it within the panel, but its SUCH a pain to re-wire the cabling.
Like I said, I'm sure somewhere here has done it !
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
jaguarbill
Sep 5, 2015 11:43 AM
