Rear brake rotors
Old Apr 11, 2022 | 03:56 PM
XKRRANDY's Avatar
Default Rear brake rotors
Is there a trick to getting the rear brake rotors off.
Old Apr 11, 2022 | 04:13 PM
Lannyl81's Avatar
If the XK8 has been in a rainy climate for a while, the rear as well as the front rotors rust at the joint between the rotor and axle. I tried using a block of wood and hammer; I tried applying a rust penetrator, then wood block & hammer. Nothing worked until I got out my mini-sledge hammer and beat the rotor off, of course destroying it in the process. I should have tried a torch....may be that would have worked...do not know.
Good luck with getting them off.
Old Apr 11, 2022 | 07:22 PM
zray's Avatar
All 4 of my rotors were frozen to the studs. No amount of beating with a mini sledge would budge them.
Finally a light bulb in my head clicked on and I bought a couple of cans of CRC Freeze Off. Spray about 1/2 a can at the studs base. Use a lot of it !!! Then the rotor will just fall off like magic.
NOTE: the fumes are toxic. Use a fan and have garage doors open.
Z
Old Apr 12, 2022 | 03:33 AM
michaelh's Avatar
In addition to the above, the rear rotors could be binding on the handbrake/parking brake shoes. Backing them off slightly will help if so.
See this thread from jagophile. It contains details of what to do and pictures :
https://www.jaguarforums.com/forum/x...5/#post2275422
Old Apr 16, 2022 | 01:14 PM
XKRRANDY's Avatar
Thanks all
It seams cleaning around the hub and studs and penetrating oil and the correct terminology while beating the crap out of the hubs with a dead blow hammer worked. I can provide a list of words and terms used in the process upon request. The freeze Off is a great option.
This is the first brake change at 37,000 miles. The original pads where directional on 355mm rotors, are they still available or is there a better option like ceramic. And why do the brake shoes show wear when never used?
Old Apr 16, 2022 | 02:31 PM
Harro10's Avatar
I recently changed my front pads and rotors. I could not get the right rotor off and tried this method which worked well for me. I only had room to use one nut on each bolt but it still worked.
Old Apr 16, 2022 | 02:38 PM
tsuppari's Avatar
I used cleaning, penetrating oil, small sledgehammer and air hammer with no success except they removed some of rust (air hammering most).
Was planning to use butane torch but was afraid that excessive heat would do damage to other parts.
Old Apr 18, 2022 | 12:54 PM
XKRRANDY's Avatar
Very helpful
Old Apr 18, 2022 | 01:12 PM
zray's Avatar
The CRC Freeze-Off is the fastest solution I’ve found , and safe with no danger of damaging parts.
……Just don’t breathe the fumes
Z
xjtom
May 24, 2021 02:04 AM
logger
Mark V - X 420G
Aug 17, 2020 10:16 PM
Robert Go
Apr 18, 2017 05:06 PM
Fastlane'scat
Feb 9, 2014 06:27 PM
g2ktcf
Mar 4, 2011 06:06 AM
