rear camber alignment
just had some rear end work. 2003 XK8
rear pads. cv joints and wheel bearings followed by alignment
shop not able to provide alignment graphic wifi issues
with some combination squares I was able to calculate rear camber as -1.67
spec is - 1.0 to -0.5
If I add additional 3.5 mm shim how much will negative camber be reduced. may not be worth it
Randy
Randy
When I worked at the dealer we asked the parts dept to stock camber shims.
They told us to pick a size as they were NOT going to stock all of them.
We settled on 6mm because that was the one that seemed to solve most of the issues.
I keep 6mm shims in stock if a customer needs one or two.
I am considering cutting some out of 1/4 plate (6.4mm) with my plasma cutter and drilling/fabricating some to try.
They used to be about $30 each when I was at the dealer but 10 years ago they were closer to $40 each.
Edited to add............
All the cars I aligned came with 4mm from the factory but 6mm seemed fix the years old suspension when the wear/settling occurred.(I have plenty of 4mm shims somewhere in the shop)
An additional 3.5mm shim will reduce camber by 1°24' (1.4°).
Have a read of this thread from HashimB:
https://www.jaguarforums.com/forum/x...3/#post2467735
phd12volt
Aug 7, 2009 11:24 AM
