Rear Quarter Glass rubber failed
Old Oct 29, 2025 | 12:46 PM
Pickett6's Avatar
Default Rear Quarter Glass rubber failed
My drivers side quarter window glass has detached its self from the mounting. The rubber joint has failed. I can't find a replacement part. Anyone know of a solution or where I might find a replacement?
Old Oct 30, 2025 | 01:43 AM
Tha Driver's Avatar
A photo would help. Windshield urethane is great for gluing glass in. That shtuff is nasty, though - if you use it make sure you have everything around the area that you don't want it to get on taped off. Some gloves to keep it off of your hands. Also some laquer thinner to wash off the excess. It comes in a caulking gun tube & once opened it will dry in the tube & can't be re-used... You can cut off the excess on the glass with a razor blade.
Old Oct 30, 2025 | 03:01 AM
Pistnbroke's Avatar
When that seal fails water runs under the back seat (goes behind trim) I took 1 gallon out ..check it
Old Oct 30, 2025 | 03:42 AM
Pickett6's Avatar
Default Photo
Old Oct 31, 2025 | 03:31 AM
Tha Driver's Avatar
Found this for you:
Also found out it's called "setting tape". 58 years of building cars & i didn't know what to call it. Go to https://www.startpage.com/ & do a search for "automotive glass setting tape".
Old Nov 3, 2025 | 05:44 AM
Pickett6's Avatar
Default Update
Just extracted carrier from the car. It’s badly corroded. It needs refurbing which I will do at some point. In the mean time I found a replacement in the USA which I’m getting shipped via family.
the joys of classic cars!!😊
doc612
Oct 12, 2024 06:58 PM
Rosevillesister
Aug 7, 2021 11:19 PM
alpecsa
Aug 24, 2015 05:44 AM
john_cook12
Jun 12, 2015 03:43 PM
Spinedoc2304
Mar 7, 2014 05:31 PM
