Rear Sills Source
Old Apr 4, 2014 | 06:50 PM
Rezzz's Avatar
Default Rear Sills Source
Both left and right side rear sills before the rear wheel well are toast. They could be patched but I'm not interested in band-aid fix and would like to source some replacement panels. Anyone sell these or know a source in the US/
Old Apr 4, 2014 | 07:33 PM
RCSign's Avatar
The rears sills are part of the quarter panel a $2000.00 part, the inner sill is part of the door assembly around $800.00 very expensive parts from Jaguar, about the only place to get the complete piece. Tony XKR Racer does many patch panels which are satisfactory when done right. I don't know of anybody doing replacement rocker panels. A good restoration or body shop should be able to reproduce the curve with minimal filler.
Old Apr 4, 2014 | 10:37 PM
Rezzz's Avatar
Well after some extensive searching I found and purchased panels from this site. I will advise regarding the quality when they arrive and are fitted.
Jag Spares International - XK8 1996-2005 - Body and Fittings
Old Apr 5, 2014 | 03:48 AM
Originally Posted by Rezzz
Well after some extensive searching I found and purchased panels from this site. ........
This must be the panel you are using?
One of the factors that influenced the decision to sell my XK8 4.2-S late last year was corrosion starting to appear in the rear sills and wheel arches.
At our forum meeting in Glasgow last Saturday, I had the opportunity to examine some XK8/XKR's and noticed rust in the same places.
I'm interested to see what you find when that outer sill section is removed.
Old Apr 6, 2014 | 02:00 PM
RCSign's Avatar
That's the first I've seen of patch panels for the XK-8, they look good. Let us know how they work out for you.
Old Jul 9, 2014 | 03:40 PM
White Bear's Avatar
My 98 Coupe has also fallen foul of the sill maggot, and I would like to carry out a permanent repair.
Have you had an oppertunity to use these replacement panels? If so how did they work out for you?
Regards,
White Bear.
Old Jul 9, 2014 | 04:08 PM
SNG Barratt USA's Avatar
Former Sponsor
For info we now offer the rear wheel arch repair panels.. Check out the link below to the products on our website. If you or anyone would like any further info on these please do not hesitate to contact me. Will also be looking at supplying the rear sill panels in the near future.
www.sngbarratt.com/PartSearchResults.aspx?partno=FJA1320AF%2fA
Regards
William@SngBarratt.Com
Old Jul 10, 2014 | 06:18 AM
RaceDiagnostics's Avatar
Great to see these repair panels becoming available.
I'm wondering what bracing would be needed on a convertible if you cut out that section of the rear sill, as it must be one of the major structural parts.
Old Jul 10, 2014 | 06:50 AM
Rezzz's Avatar
Wink
Regards,
White Bear.
As you note I have purchased the panels but to date I have not installed them. I am in the process of a restoration and have started with the drive train https://www.jaguarforums.com/forum/x...1999my-116832/ upon completion I will be moving onto the body and will photograph all of the repairs so you should be able to see it on the link above in about a month or two.
Old Jul 10, 2014 | 06:52 AM
Rezzz's Avatar
Regards
I am not in need of these at this time but SNG has been fantastic for me to date. Great prices and timely deliveries. If I need them then you will be my source.
Old Jul 10, 2014 | 08:25 AM
Rezzz's Avatar
Yes it is. Once they cut out the section I will photograph whats behind
H20boy
Dec 24, 2024 03:23 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
