Rear speaker(s) on my newly bought XK8 Conv
Old 10-18-2014, 11:32 AM
LondonXK8Boy's Avatar
Default Rear speaker(s) on my newly bought XK8 Conv
I have today managed to secure a stunning 98 XK8 Convertible. I love it.
Everything has been done inc timing chains and it's running just perfect
Anyway - the rear speaker on the passenger side seems to be knackered, it works but its farting away with the bass - i have everything set to 0 - so it's not the settings - do you access them by just pulling the cover off or what - how do you get at it? cheers.
Attached Thumbnails Rear speaker(s) on my newly bought XK8 Conv-img_1862.jpg
Old 10-18-2014, 11:52 AM
jodypress's Avatar
It's dead easy to replace. I did my rears last year.
There's a guide somewhere on here, I'll see if I can find it. Whereabouts in London are you? I'm in hackney and could show you how to do it in about 10 mins. (I've had a lot of practice removing most of the interior, what with roof hoses and speakers etc)
The following 2 users liked this post by jodypress:
JimC64 (10-18-2014), LondonXK8Boy (10-18-2014)
Old 10-18-2014, 02:57 PM
PM'd u jodypress - are they a standard size?
Is this what i need? NEW JAGUAR HARMAN KARDON SPEAKERS LJA4140BD | eBay
or is this what i need?
http://www.ebay.co.uk/itm/1998-1999-...item1e89d8a7cb
Old 10-18-2014, 03:35 PM
johns427's Avatar
Make sure you buy good quality 2 ohm woofers, not speakers. I bought 4 ohm cheap woofers and they sound terrible. Cant turn the bass up above zero without all kinds of flutter. Now I have to do it again.
LondonXK8Boy (11-14-2014)
Old 10-18-2014, 05:28 PM
DevonDavid's Avatar
Maybe not good enough for the ardent audiophiles, but three months on, I'm still very happy with my fairly low cost solution :
https://www.jaguarforums.com/forum/x...io-fix-118911/
johns427 (10-18-2014)
Old 10-19-2014, 11:27 PM
Johnken's Avatar
Received 1,808 Likes on 1,115 Posts
I remember a time when I installed some nice aftermarket woofers that burped and rattled every time a good bass note came. It was a learning for me - when a woofer isn't properly secured (tight screws), the speaker basket itself moves in opposition to the speaker cone (even slightly), causing this kind of distortion. From what you said (happens at low volume), I don't think this applies, but hey you never know so take this as an FYI for the future reference just in case you didn't know this already. One more thing while we are discussing woofer installations - way too many of us, myself included, have done this once or twice: It is incredibly easy to spear your speaker. Always protect the speaker driver from your screwdriver with your free hand when screwing them in. I cup my hand around the end of the screwdriver. That woofer's magnet plus bad luck makes it way easier than you think for the screwdriver to slide off into and right through your new speaker. Trust me you can't react fast enough once it starts to slip. By the time your realize what just happened, the screwdriver is burried in your brand new speaker's surround. John
Old 10-20-2014, 08:12 AM
aode06's Avatar
https://www.jaguarforums.com/forum/x...peakers-36543/
the diagram is at the bottom
Old 11-05-2014, 08:05 AM
Hi Guys - now i am just assuming the rear speakers are knackered, it's not that they might not be screwed down correctly?
Prob are knackered - can someone please point me in the direction of replacement ones?
eBay link etc.
98 XK8 Conv in London UK.
Cheers.
Old 11-05-2014, 11:59 AM
DevonDavid's Avatar
Did you follow my link from a couple of posts above here, plus ...........
Car Audio Equipment | Buy online at Car Audio Security
Old 11-05-2014, 12:20 PM
K.Westra's Avatar
Kicker CVT65 subwoofers fit in the factory location with minor plastic removal on the speaker and pretty decent, even when powered by the factory amp.
Old 11-05-2014, 01:36 PM
DevonDavid's Avatar
Keith - the Kickers are very difficult to get here in the UK and I could only find US suppliers, which would have meant big freight charges plus import duty etc. The JBLs are easy to get here, and although I don't think they are as good, I'm still happy with mine after 6 months or so ........... I'm a "quite like it loud but not so my ears bleed" sort of guy so keep the volume at a reasonable level (rarely take it up to "11" !!)
Old 11-05-2014, 05:32 PM
DaveC's Avatar
I used some shallow depth front throw subs I got off of Amazon for about $100/pair. Worked fine in a comvertible. I had the Harmon Kardon system.
Old 11-06-2014, 12:36 PM
I'm taking the car to the place i bought it and they are going to sort me out - news at Eleven
Old 11-14-2014, 03:10 PM
Ok i have sourced rear speakers from same year and model as my car 1998 XK8 Conv. Is there any stickies/vids around on how to remove/replace ?
Cheers.
99xk8guy
06-05-2023 06:28 AM
PMKimpton
08-03-2019 08:22 PM
brgjag
General Tech Help
17
09-09-2015 07:34 AM
RaceDiagnostics
09-07-2015 07:28 AM
obwoodie
09-03-2015 07:45 PM
Quick Reply: Rear speaker(s) on my newly bought XK8 Conv
