Reflash
Old Apr 26, 2021 | 02:34 PM
stephenniz's Avatar
Default Reflash
I have a 2001 XKR convertible. I was putzing around in the car today and found a Jaguar sticker stating that the car has been reflashed/approved by Jaguar. Is anyone familiar with this ? Ive owned the car for less than a year.
Old Apr 26, 2021 | 02:44 PM
Jon89's Avatar
What "reflash" was performed? If you provide the string of letters and numbers referenced on your paperwork, someone here will be able to tell you exactly what was done....
Old Apr 26, 2021 | 02:51 PM
stephenniz's Avatar
I just checked the sticker and all it has is factory authorized and reflash written on it. I have no paperwork on the reflash.
Old Apr 26, 2021 | 04:14 PM
fmertz's Avatar
Reflash means the software of either one (or more) control modules or the ECU itself was updated. There are a number of scenarios
  • An updated purge valve was installed and the new version requires an accompanying code change
  • A control module was replaced and ran a newer version as compared to the original module. The ECU had to be told to trust it (VCATS logic)
  • The ECU had to be replaced and reprogrammed for your country and for the modules actually installed in your car.
  • A prior owner complained about something and the ECU was updated to run a later version
  • A prior owner installed the cabin air filter and an accompanying code change was done to up the A/C fan air flow
  • (less sure of this one) The shifter light module was replaced with the later reman model requiring updated CAN messages
I am sure there are others...
Old Apr 26, 2021 | 04:20 PM
stephenniz's Avatar
Thanks.
The reflash was done in 2002 so it wasn't long after the original owner bought the car.
Old Apr 26, 2021 | 08:54 PM
motorcarman's Avatar
Probably 303-49 or 303-53
File Type: pdf
Old Apr 27, 2021 | 07:01 AM
stephenniz's Avatar
That is what it probably is. The dates line up. Thank you.
Davidd 21
Oct 30, 2012 12:11 PM
chuckarn1
Jul 25, 2012 05:21 PM
azeteg
May 31, 2012 09:24 AM
lcyoung
May 10, 2012 11:48 PM
lcyoung
May 7, 2012 06:06 PM
