Removed drained battery,recharged,reinstalled,now no start? Please help
Old Dec 2, 2014 | 08:16 AM
  #81
aode06's Avatar
Call a flat bed, leave your key and key fob with the car, tell Jaguar(or some locksmiths do this service), you removed the battery and the key you have will not shut the alarm off, and needs to be programmed back onto the system.
Old Dec 2, 2014 | 08:54 AM
  #82
Gus's Avatar
Gus
The exciter ring reads the chip that is located in the key that was programmed to start the car. If you have more than one key I would recommend that you try them all. If all the keys fail to start the car then I would first check the exciter ring. The exciter ring is mounted around the ignition key cylinder and can be checked by using an ohm meter and measure the resistance to 30 to 35 ohms.
Link to TSB 303-55 http://www.jagrepair.com/images/TSB/...rd%20Start.pdf
It is also mentioned in my No Start procedure on my page.
Originally Posted by Hi-Velo-Sid-E
Hi Gus, how do I check it ?
What does it look like?
How do I access it?
How do I confirm if its reading or not?
Also, a few posts back someone suggested I rub the key on the battery neg post, would that mess up the key code?
The car battery is what went low so the key should be fine.
Thank you,
Sid
Old Dec 2, 2014 | 05:03 PM
  #83
Hi-Velo-Sid-E's Avatar
Originally Posted by Dennis07
Hang in there, Sid
Keys with a black background are owner keys; those with a green background are valet keys. I believe this is true for all MYs.
Jandreu's post #72 makes the pivotal point: the evidence seems to be telling us that your key is not recognized. So I think pursuing that issue is a better use of your time right now than tracing through fuses and relays and such.
Hi Dennis07, thanks for clarifying the key color question.
I too agree there is an issue about the key not recognized, however is the issue the key or something else?
Jaguar quoted $157 to reprogram plus towing, then if thats not it i would be stuck with the car there and possibly paying for them to experiment further or paying to tow it back.
Thank you, much appreciated,
Sid
Old Dec 2, 2014 | 05:19 PM
  #84
Hi aode06, good thing that this can be done by other than Jaguar dealers.
I just called one locksmith who told me he can come to me to do it for $145.
I will shop it around to find out what the average cost is.
Sid
Old Dec 2, 2014 | 05:29 PM
  #85
I would hate to go through this again due to another possible battery removal and reinstall or replacement, especially if/when away from home.
Is there any way to circumvent this part of the security system?
Thank you
Sid
Old Dec 2, 2014 | 09:59 PM
  #86
I found a website that sells Jag keys and states the key is precloned.
Does that mean that all 99 xk8 keys have the same transponder code and that only the ingnition/key teeth patterns are different?
The key ad:
Works on the Following Models:
Jaguar XJ8 1998-1999
Jaguar XJR 1998-1999
Jaguar XK8 1997-1999
Jaguar XKR 1997-1999
Replaces the Following Key Types:
JMA TP05JAU.1.P
Ilco TBE1T5
HNA-7230AA1
Reusable: Yes
Cloneable: Yes
Chip: Pre-Cloned T5 (Megamos 13)
Test Key: Tibbe 8-Cut
Thank you,
Sid
Old Dec 2, 2014 | 10:22 PM
  #87
Dennis07's Avatar
I found a website that sells Jag keys and states the key is precloned....
Thank you,
Sid
Sid,
I think there has to be more to it than this, otherwise everybody's key would start everybody else's car if the teeth were made to align.
Old Dec 2, 2014 | 10:34 PM
  #88
Sid,
Hi Dennis07, I agree, but you read my question too quickly .
My question was/is;
Thanks again,
Sid
Old Dec 2, 2014 | 10:37 PM
  #89
Juke's Avatar
Good luck brother!
Old Dec 2, 2014 | 10:46 PM
  #90
Dennis07's Avatar
My question was/is;
Thanks again,
Sid
Sid,
I got it about the teeth pattern, but it seems unlikely to me they'd use the same chip + same coding in all cars, and count only on teeth pattern to keep key "A" from working in car "B".
Old Dec 3, 2014 | 07:42 AM
  #91
Sid,
I got it about the teeth pattern, but it seems unlikely to me they'd use the same chip + same coding in all cars, and count only on teeth pattern to keep key "A" from working in car "B".If they were going that way, why bother with the chip?
So they can rip us off hundreds of $$$ per occurence, per customer, for reprogramming or for immobilize resets.
Thank you,
Sid
Old Dec 3, 2014 | 03:32 PM
  #92
Dennis07's Avatar
Sid,
Hey, two quick thoughts:
What happened to you here would not normally occur because of a battery removal, so with a little luck this should be a one-time event. WhiteXKR posted a few days back that the data may have been lost as part of a jump-starting attempt. When you get back in business, there are procedures to minimize the risks should you ever need to jump the car again. Better not to if you can avoid it.
The locksmith will come to you, correct? Sounds like the way to go since then no flatbed required. You'll know immediately if he got it fixed before opening your wallet.
Hang in there ...
Old Dec 5, 2014 | 03:05 AM
  #93
bakntyme's Avatar
Sid
If that were true, there would be no reason to require key programming. Every key having the same transponder code is functionally identical to no key having a transponder code.
Old Dec 5, 2014 | 11:36 AM
  #94
Chuck Schexnayder's Avatar
Unless that car key person, that will come to you, is a very rich key guy, the only people I know of who can program a key to your car are the Jaguar dealers. However, he may be a former Jaguar employee who "borrowed" the dealer's. equipment ;-).
Just beware.
Chuck
05/XK8/Vert/C.F.
Old Dec 6, 2014 | 05:33 AM
  #95
aode06's Avatar
this is an example, you do not need jaguar lol.
If your key is lost by the security module,as to why this may of happened, the only explanation is that Jaguar techs explained, they have modules do things like this all the time with a drained /or shorted battery.
Old Dec 6, 2014 | 12:16 PM
  #96
aode06,
Well that shoots my two cents above in the foot. But, no mention of what these people charge to do these key procedures. I (sort of) timed the video's and except the one where the guy goes away and comes back, the procedure lasted may be 3 min. That would have saved me a 300 mile round trip and about 300 bucks if I could find one of these guys.
Chuck
05/XK8 /Vert/C.F.
Old Dec 8, 2014 | 01:20 AM
  #97
aode06's Avatar
$150 in ebay,Jaguar security has been hacked brothers
New Car Auto SBB V33 02 9 Languages Immobilizer Multi Brands Key Programmer | eBay
Old Dec 8, 2014 | 05:37 AM
  #98
RJ237's Avatar
My 97 xk8 does not have a chip in the key. Is everyone positive the other early cars have chips?
Old Dec 8, 2014 | 07:27 AM
  #99
Gus's Avatar
Gus
I am not positive but I think it was installed in the MY 1999.
Old Dec 8, 2014 | 08:22 AM
  #100
DevonDavid's Avatar
Is that correct ??
Mine is a 1997 (UK) car and I'm pretty sure it has a "transponder" in the key. Not a great photo, but you can see a small circular "plug" on the side of the key which is where the transponder is inserted.
Removed drained battery,recharged,reinstalled,now no start? Please help-jaguar-key.jpg
