Removing emblem and badges off the XK8?
Old Oct 25, 2013 | 10:28 AM
Windycityx's Avatar
Default Removing emblem and badges off the XK8?
What is the best way to remove the emblems and badges off the car? I would like to not damage or break them when removing...
Front grill emblem
Two green side oval leapers
Jaguar emblem on boot
XK8 key hole emblem on boot
Old Oct 25, 2013 | 10:38 AM
aode06's Avatar
BODY SHOP,DIRT CHEAP
On mine, they used a heat gun to warm the emblems, a tool like a 90degree pick, precision.Then 3m adhesive remover and a rag to remove residue from the clear. Regardless,jag used so much clear, you can tell the emblems were there.
$40
Past attempts by me have cost clear-coat jobs, I did not have access to a heat gun or that metal 90 degree pick and 3m adhesive remover.
Old Oct 25, 2013 | 10:56 AM
glenonoka's Avatar
If you don't have a heat gun, you can use dental floss to separate the badge from the car and then goo gone to remove the leftover adhesive.
Old Oct 25, 2013 | 11:29 AM
Windycityx's Avatar
Are the green oval leapers on the sides just sticker emblems as well, no bots etc?
Old Oct 25, 2013 | 11:41 AM
WhiteXKR's Avatar
You probably do not want to remove those. There is a hole there for side marker lights used in non-US markets.
Old Oct 25, 2013 | 12:41 PM
The Front Bumper Badge is both glued and secured with a star washer (see item 3):
There is also a circular hole through the Bumper visible when it is removed.
Old Oct 25, 2013 | 01:54 PM
Windycityx's Avatar
I was just going to use a hot air gun to remove all the emblems and replace the:
Front emblem with this winged one
Green side leapers with the same ones, just in black (couldn't copy pic)
Left boot Jaguar one with this leaper
Right boot keyhole XK8 with this one
Think I will have any issues?
Attached Thumbnails Removing emblem and badges off the XK8?-fe00d4f7a6aa28cd85cf7a3f7975d9c3.jpg   Removing emblem and badges off the XK8?-%24-kgrhqr-nke63u-fw-dbpbl1nctz-%7E%7E60_12.jpg   Removing emblem and badges off the XK8?-%24-kgrhqn-hme9ejjpzsvbpt-o2s58-%7E%7E60_12.jpg
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
hoodun
Sep 13, 2015 03:55 PM
David Thompson
Sep 3, 2015 07:48 PM
davidladewig
Sep 3, 2015 06:32 PM
