Replace Hazard Lights Switch
Old Aug 20, 2021 | 08:03 AM
MickeyR's Avatar
Default Replace Hazard Lights Switch
Reconnected the battery after sitting a while, and everything is fine, except hazard lights are stuck on. Switch doesn't feel right - not much movement. How do you remove the panel to replace it?
Thanks!
Mickey
Old Aug 20, 2021 | 08:53 AM
Jon89's Avatar
I remember reading that some owners have been successful shutting off a stuck hazard switch by forcing the edge of an old credit card underneath it....
Old Aug 20, 2021 | 08:59 AM
MickeyR's Avatar
Thanks, Jon. After I posted, Kelly sent me a PM and shared how he turned his off. Looks like the whole bank of switches has to be replaced as a unit! And SNG Barratt shows "Unavailable".
Old Aug 20, 2021 | 09:29 AM
bladerunner919's Avatar
Unlikely it needs replacing, just cleaning. One they're out the're easy to take apart and clean up whatever has gummed it up. Taking it out is the most challenging part of the process as the centre console has to come out. Even that is very straightforward:
Old Aug 20, 2021 | 06:10 PM
Red's Avatar
Red
Yep, disassemble, then clean & lube the button and don’t over-tighten when reinstalling.
Old Aug 20, 2021 | 06:59 PM
Gas turbine's Avatar
+1 to not over tightening
Old Aug 20, 2021 | 08:58 PM
crbass's Avatar
Default Makeup tools
Frankly, while taking apart the console is entertaining (in addition to not tightening down too aggressively on the wood brackets, make sure the wood brackets are headed in the correct direction. Rev Sam has them swapped to the wrong side, I believe), jamming a moistened microswab or six for a quick tour around the gap has always fixed this for me without removing anything. Microswabs repurposed from women hanging around the house shown below.
Microswab stolen from womenfolk.
One microswab jammed into the gap, the other hanging out in space. A little 409 (or water), a couple of circuits around the switch, and voila, doesn't stick any more.
Old Aug 20, 2021 | 11:25 PM
Johnken's Avatar
Cool, I've gotta track down some of those micro swabs!
John
Old Aug 21, 2021 | 07:10 AM
MsMaybe98's Avatar
John
Your local Reeds, CVS or Walgreens should carry them. In the cosmetics aisle.
Old Aug 21, 2021 | 07:15 AM
MickeyR's Avatar
Great tips, all - thanks so much!
Old Aug 21, 2021 | 09:27 AM
crbass's Avatar
John
Asked my supplier (pusher), she said:
Amazon Amazon
Old Aug 21, 2021 | 02:01 PM
You'd probably be able to just spray electrical contact cleaner into the gaps around the button to get it cleaned off and working.
Old Aug 21, 2021 | 03:28 PM
giandanielxk8's Avatar
I have done this and it doesn’t work nearly as well as I thought it would. What did work for me was loosening the screws that hold the buttons to its bracket just a tad.
Old Aug 22, 2021 | 05:43 AM
MickeyR's Avatar
Tried that, but no joy. Now I'm out of contact cleaner!
Thanks - will give that a go.
benzjag
Apr 9, 2025 05:24 PM
Scott_XJR
Dec 19, 2020 02:23 PM
shreddie44
Nov 30, 2017 03:04 PM
Daf11e
Apr 16, 2015 11:53 AM
