Replaced air intake hose problem
Old Mar 20, 2012 | 06:59 PM
Markarras's Avatar
Default Replaced air intake hose problem
I just replaced the black air in-take hose and not sure if I installed it right.
my other one was broke and I didn't pay enough attention when I removed it. There was a bottom piece that was connect to the base that didn't come with new hose, I just can't seem to figure out how that fits.
Old Mar 20, 2012 | 07:43 PM
test point's Avatar
Welcome to the forum and I would really like to help but I cannot understand the problem and question.
Old Mar 20, 2012 | 08:02 PM
Do you mean the round black hose from the air filter housing to the throttle body?
Old Mar 21, 2012 | 05:16 PM
Markarras's Avatar
Yes it a little black round rubber part that sits between the hose and the
there are 2 screws used to tighten it down but not sure how the little round thing coonects between the base and the hose
Old Mar 21, 2012 | 05:36 PM
The Coupe's Avatar
Sounds like you're talking about the rubber seal between the intake tube and the throttle body.
Just fit the seal to the intake tube...it has a groove around its circumference...and then lower the tube and seal onto the round throat of the throttle body. Make sure the seal isn't folded on itself before you tighten the tube down with the bolts...you want an airtight seal.
Old Mar 21, 2012 | 05:50 PM
Markarras's Avatar
I just went out and took it apart again. Coupe thanks for the feedback, your right on.
Knew this was the right place....thanks again
Old Mar 21, 2012 | 06:00 PM
NikasilNik's Avatar
Glad you have it sorted ,
Nik
Xj812
Oct 26, 2015 05:04 AM
gene1
Sep 3, 2015 08:04 PM
casepie
Aug 30, 2015 09:49 PM
gene1
Aug 27, 2015 09:35 PM
dpappyp
Aug 27, 2015 06:31 AM
