Replacement ECU causing different transmission behaviour
Old Mar 16, 2026 | 09:29 AM
2500DollarXKR's Avatar
Default Replacement ECU causing different transmission behaviour
EDIT: Replacement MAF. Not ECU. Gaaaaah.
Still tracking down long crank times when cold, and decided to do some preventive work and swap out the MAF with a generic one for troubleshooting purposes (part matched at least). I know the experiences with non-Denso MAFs have been pretty poor, but this was just done in an effort to see if there was something nuanced about the IAT1 in the MAF that was causing the long crank. another EDIT: 25F start this morning was < 1 sec. Last run was approx. 18 hours ago so fuel drain down would have occurred if check valve.
In replacing the MAF, has anyone experienced different or more deliberate shifting by the transmission? Everything seems fine, but it's revving higher and staying in 2nd and 3rd longer before a lurched shift into the next gear. I have reset the vehicle (via the battery cable method, let it sit) but I didn't want to drive anything extended for fear of causing other issues. No OBD codes. I can always go back to the old MAF- I still haven't pinpointed the long crank. My thinking is that it is still adapting from default profile and relearning based upon a wildly different airflow profile from the new MAF, and that I should give it some time. Thoughts?
Last edited by 2500DollarXKR; Mar 16, 2026 at 10:03 AM. Reason: wrong title. Should read MAF.
Old Mar 16, 2026 | 11:54 AM
Pantera928's Avatar
This is the mercedes gearbox, not the ZF, correct?
Old Mar 16, 2026 | 12:02 PM
Correct. 2001 XKR
Old Mar 16, 2026 | 01:04 PM
wymjym's Avatar
I though the transmissions 'learned' your driving style over a few driving cycles of 15 miles or more.
wj
Old Mar 16, 2026 | 03:00 PM
JagV8's Avatar
Maybe a small air leak? That would cause higher revs. Fuel trims will show if so.
Old Mar 16, 2026 | 03:06 PM
Guys, I just pulled that aftermarket MAF. I was getting WOT readings in the 300s on it via Torque and, unless I've suddenly increased my displacmeent by 2x, those aren't realistic numbers. The reason why it probably cured my long cold crank times was enriching the mixture, albeit falsely. Going back to the old MAF "cured" the weird shifting. In any case, back to the drawing board.
Old Mar 16, 2026 | 03:35 PM
motorcarman's Avatar
You need to disconnect the battery power from the ECM to clear all the adaptations if you want a reading from ZERO trims.
You can disconnect the battery OR pull the ECM fuse for a while to drain the capacitors.
The trims will just pick up where the ECM left off unless you clear the trim adaptions with a BATTERY POWER OFF.(not just ignition off)
Quadcammer
Aug 29, 2024 04:32 AM
Bosco15
Oct 29, 2022 12:55 AM
scooterforever
Jul 30, 2022 11:53 PM
SC Chinchilla
May 5, 2022 02:08 AM
AlbBolivar
Apr 3, 2015 12:09 PM
