Replacing 2004 xkr rear bearing
Old Jun 22, 2016 | 01:49 PM
Jag1968's Avatar
Default Replacing 2004 xkr rear bearing
Hi fellow jag lovers
New to the forum and any help greatly appreciated
Got bad rear bearing and after a couple of days of reading
Up on forums thought I would have a go managed to take of calliper easy enough next remove disc after a day of bashing
With hammer and piece of wood to no avail today I got a bigger hammer relief it started moving managed to get disc/drum to rim of the HUD but can't get it any further
I've slackened of adjuster but can't get passed shoes
Am I missing something
Thanks for any help
Old Jun 23, 2016 | 09:20 AM
Welcome to the forum Jag1968,
Are you CERTAIN you've slackened off the adjuster?
It's clockwise to slacken and anti-clockwise as shown here to tighten:
Old Jun 23, 2016 | 10:08 AM
Jag1968's Avatar
Thanks for the response Graham I've adjusted both ways to make sure took shoe to biting point and gone other way as far as
Possible with free moving drum I've also slackened hand brake cable as well to make sure it was as clear as possible
Old Jun 23, 2016 | 03:30 PM
phanc60844's Avatar
When i changed my rear discs i had to hit the disc so hard it broke before it would come off, no help to you as I'm sure you want to reuse them
Old Jun 23, 2016 | 03:43 PM
brgjag's Avatar
I was at a chain repair shop one time getting an oil change. Some old lady had a toyota what ever that she clearly had been driving for some time. She was there for a brake job. The guys in the shop could not get any of the discs off the car, they told her to take it to a dealer. ha ha ha
Old Jun 23, 2016 | 03:49 PM
Jag1968's Avatar
I'd rather not brake them. the disc is freely moving
And I can slide the drum up and down the studs by hand
But jams up as it gets to the edge of the hub and jams up
In the hub carrier there is a sensor I've disconnected the cable
But the sensor is still in the carrier I've also removed the axle nut but I can't see this being the problem is there any thing I could!d have missed
Old Jun 23, 2016 | 03:55 PM
plums's Avatar
You removed the caliper bracket right?
Old Jun 23, 2016 | 04:09 PM
Jag1968's Avatar
I removed the caliper from there mount on the hub carrier
Didn't notice any mount I've got the bembro calipers just had
Quick look they don't have separate mount
Old Jun 23, 2016 | 04:16 PM
Jag1968's Avatar
Sorry I might not have been clear in last post they don't have separate bracket
Old Jun 23, 2016 | 04:53 PM
Piersman's Avatar
It's most likely to be a ring of corrosion around the inner edge of the drum part of the disc assembly, isn't it?
Usually the drum brake linings inside the disc for the handbrake keep a centre band of metal nice and clean. The bits either side of the shiny band rust up and the rust expands so when you try to pull the disc off the rusty bit catches on your shoes, even if you've slackened them.
Hit around the edge with a claw hammer to see if you can 'shock' away some of the built up rust. Then pull the disc/drum towards you and see if you can hit it from behind, although usually the dust plate makes this a PITA.
If you can get in behind at all, maybe see if you chip away at the rusty ring - which sounds wrong on many levels, but I hope you know what I mean
Old Jun 23, 2016 | 05:14 PM
Jag1968's Avatar
Well it would take my mind of the car piersman but she's already
Gone to bed and she doesn't like it when I wake her up back to the car with the drum pulled out as far as I can get it I can actually see 5mm of the shoes so it seems to be past any rim
If there's nothing that I haven't released I guess it must be just jamming up on the shoes
Old Jun 23, 2016 | 05:56 PM
Piersman's Avatar
In that case, just keep hitting it harder! It'll come off.
Old Jun 23, 2016 | 06:31 PM
Jag1968's Avatar
I'm going to get a plank across the studs and a couple of g
Clamps on the back of the discs and do some more bashing
I'll let u know how it goes thanks for it input fellas
Old Jun 24, 2016 | 04:29 PM
Jag1968's Avatar
Hi again fellas success at last tried hammering disc of again
Wasn't working and when drum was of as far *** I could
Get it drum was still turning freely so decided it must be
Something else decided to grab file and file rim of hub
After a little filing drum slipped straight off it would appear that the edge of the edge of the cylindrical hub center was a fraction out of shape witch was enough to stop it slipping of now can anyone suggest a good place for me to get bearings and shim's
Old Jun 25, 2016 | 09:29 AM
Originally Posted by Jag1968
........now can anyone suggest a good place for me to get bearings and shim's.
Good to hear it's off at last!
Your latest question - a perfect example of why we ask members to put a Location in their profile and vehicle details in their Signature.
As you're in the UK, I'd suggest S N G Barratt in Bridgnorth (forum sponsor and good prices) or Jaguar Spares North East in Peterlee (good prices for brakes and bearings).
Old Jun 26, 2016 | 01:29 PM
Jag1968's Avatar
Thanks Graham thought I had put photo on a model but doesn't seem to have come up I'm in Croydon by the way
Thanks mate
Old Jun 27, 2016 | 02:54 PM
Jag1968's Avatar
Hi guys managed to remove hub carrier now I need to separate
Old bearings do I need to remove wheel sensor speed cog
And is it just a case of hammering out from rear of hub
Thanks for any help
NCJagman
Apr 15, 2016 12:40 AM
revski666
Apr 5, 2016 05:42 AM
iownme
Apr 1, 2016 05:20 AM
kenatofc
Mar 28, 2016 02:53 PM
Guernz
Mar 26, 2016 09:30 AM
