replacing dash lights
Old Dec 3, 2011 | 11:06 PM
Bigvettefreak's Avatar
Default replacing dash lights
How do I remove the section for the trac, heated seats buttons, 4 ways etc?
The bulbs for the trac. button is out and the little red light is out for the driving lights when you turn them on.
I found the bulbs but I need to know how to get them apart.
Old Dec 4, 2011 | 11:57 AM
WhiteXKR's Avatar
You need to remove the J-gate surround and the center console. Then just remove the screws retaining the unit. See Sam's videos: https://www.jaguarforums.com/forum/x...minutes-60147/
The backlight lamp is plug-in repaceable ...the driving light LEDs are not. Those driving light LEDs are actually green and yellow and rather dim. Turn your headlights on and your dash brightness to max. and then further until it clicks (little knob on the left of the streering column) to make sure those LEDs are really out.
If those LEDs are really blown you have a few choices:
-Get a new or used replacement module
-Solder in new LEDs yourself
-PM me for details, I have replaced the LEDs on a couple of these for other folks for a nominal cost.
Last edited by WhiteXKR; Dec 4, 2011 at 12:33 PM. Reason: added turn headlights on to test LEDs
Old Dec 4, 2011 | 06:26 PM
My main concern is the back light for the Trac button, It is out & you can't see it at night. The little red light for the fog light is not really a problem.
Thanks for the link to the video. I guess I will do the back light for the Trac button and live with the other one.
peterg19
Aug 30, 2015 08:48 AM
Jandreu
Aug 29, 2015 07:31 PM
stetson1
Aug 27, 2015 07:49 AM
divingmom
Aug 25, 2015 07:54 PM
