Replacing Side View Mirror Glass - Question
Old Sep 7, 2021 | 10:27 PM
Msterieus's Avatar
Default Replacing Side View Mirror Glass - Question
Hello, Jag enthusiasts. I have a dumb question: The right side view mirror on my 1998 XK8 somehow swung in while I was driving, and the mirror broke. (I GUESS that's what happened, anyhow -- I heard a loud bang while driving and, about an hour later, I discovered the broken, folded in mirror.) Anyhow, only the glass was broken, and I bought a replacement mirror. I tried to remove the glass and base from the rest of the unit, but I was nervous about detaching the two wires. They are held onto the base with rubber thingies, and when I gently tugged on the rubber thingy to detach the wire, I got some resistance. I was afraid to pull harder, in fear that I might tear or break something. So that's the dumb question: How do I detach the two wires from the base - do I just pull them off?
Thank you in advance.
Old Sep 8, 2021 | 02:05 AM
There's a harness connector and fixing screw which must be accessed from inside:
However, if only the glass is broken, I would just change that.
Old Sep 8, 2021 | 11:53 AM
Msterieus's Avatar
Thanks, but that wasn't the question. Guide simply says "disconnect [mirror from wires]" Question was HOW TO DISCONNECT - just pull?
Old Oct 3, 2021 | 06:16 PM
Msterieus's Avatar
I am only replacing the GLASS. I cannot disconnect the WIRES.
JagHag36
May 14, 2018 02:25 PM
Dercent
Feb 9, 2018 09:52 AM
DavidJC
Sep 11, 2017 08:13 AM
Ziggy
Jul 16, 2014 05:24 AM
Jaguar6286
Jan 6, 2012 07:09 AM
