Replacing the Thermostat on 1997 XK8
Old Dec 31, 2013 | 02:20 PM
mjlaris's Avatar
Default Replacing the Thermostat on 1997 XK8
I have a friend in Las Vegas with a 1997 XK8 (only 30k miles). She needs to get the thermostat replaced and the shop (All European) is quoting her $700. This seems very high. Anyone have a good estimate on what something like this should cost. Also, can any Vegas member recommend a good independent shop in Las Vegas?
Mark
Old Dec 31, 2013 | 02:44 PM
test point's Avatar
I completely agree with your opinion of the cost . . . but . . . that is a 16 year old car even with 30k miles and with, most likely, the original thermostat, coolant, hoses and everything else. All the above and probably a number of other things will end up being changed above a $20 thermostat.
A recommended local indy is, indeed, a financially appropriate solution and it still may end up at or above the $700.
. . . and don't forget the tensioners!
Old Dec 31, 2013 | 04:25 PM
mike66's Avatar
I'll fly to Vegas and change it out for her for $650.00
Old Dec 31, 2013 | 06:21 PM
spuddyo's Avatar
One hour labour and $50 for a thermostat. If extras are included like hoses etc then the cost will be higher, but just for the thermostat, $150 tops and that is still expensive.
Old Dec 31, 2013 | 06:59 PM
mjlaris's Avatar
That's what I thought but wanted to make sure. These are Jaguars after all. Thanks for the help.
Mark
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
