Restricted Performance - Temp Gauge on HOT
Old Jan 2, 2009 | 01:18 PM
GordoCatCar's Avatar
Default RE: Restricted Performance - Temp Gauge on HOT
I can explain the suddenness of the dial movement. The temp gauge is not a linear analog in the sense it registers the movement of actual engine water temperatures. It is more like a limit-type gauge. As long as your engine water temp is within the specified limits it reads normal. If temps exceeds the range of the specs, say something around 200-220'?, then the needle immediately jumps to the hot side of the dial.
If the actual engine water temp proved to be within operating range, the sender unit or an ECU parameter could be at fault. Either way you need to first get an OBD II code reading to determine the next step in your troubleshooting. gordo
Old Jan 2, 2009 | 01:40 PM
No; if your engine water temp was say 220 degrees, it would take 15-20 minutes for it to cool down enough to remove radiator cap. There is most likely another cause for this problem. As I suggested, you need to have the codes read to logically plan your next move. It maybe something simple like a water temp sensor that is a five minute fix costing less than $50. Get your codes read. gordo
Mac Allan
Oct 27, 2015 04:49 AM
abonano
25
Sep 25, 2015 10:43 AM
1100me
Sep 7, 2015 06:26 AM
Bcrary3
Sep 3, 2015 03:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
