Can I buy just this fender clip for the fender emblem? I lost my original when I found the emblem hanging as the double faced tape had dried up on the back side. I disconnected it but the spring got away from me, and I never found it again. I have googled and looked around, but have
not found anything as of yet.
Probably not available separately from an auto parts seller. You may have more luck if you can find a website that sells various kinds of metal clips and fasteners....
Pretty common on some older fuel injection systems. I had to figure this out when I moved my blinkers and wanted to make extensions to plug into the factory harness. Your local performance shop might have just a clip but the whole assembly is cheap enough to forego the trouble.
