Retaining clip for fender emblem? 1998 XK8
Old May 26, 2021 | 07:43 AM
moparmusclecars's Avatar
Default Retaining clip for fender emblem? 1998 XK8
Can I buy just this fender clip for the fender emblem? I lost my original when I found the emblem hanging as the double faced tape had dried up on the back side. I disconnected it but the spring got away from me, and I never found it again. I have googled and looked around, but have
not found anything as of yet.
Old May 26, 2021 | 09:19 AM
Jon89's Avatar
Probably not available separately from an auto parts seller. You may have more luck if you can find a website that sells various kinds of metal clips and fasteners....
Old May 26, 2021 | 08:26 PM
rothwell's Avatar
Its called an EV1 connector.
Pretty common on some older fuel injection systems. I had to figure this out when I moved my blinkers and wanted to make extensions to plug into the factory harness. Your local performance shop might have just a clip but the whole assembly is cheap enough to forego the trouble.
About $8 at
Amazon Amazon
KayScotts
Aug 12, 2024 01:26 PM
dennysjag
May 1, 2022 05:53 PM
moparmusclecars
May 26, 2021 02:06 PM
rsgensburg
Oct 30, 2014 03:54 PM
Kadmiri
Sep 27, 2012 12:22 PM
