rough idle, dies
Old Aug 29, 2025 | 07:46 AM
  #61
zray's Avatar
Originally Posted by dibbit
And unfortunately "never" is how long it takes some people to reset their readiness monitors. People need to be aware that a hard reset isn't some magic cure all that fixes all problems, it can in fact introduce a new problem that will make their car impossible to get registered depending on where they live.
More people need to understand this.
do you have a theory why the readiness monitors in some cars reset quickly, while other cars take much longer, or “forever”as you suggest ?
Example : my 2002 4.0 XKR will be ready for inspection just minutes after a hard reset.
ready to learn more about these fascinating machines.
Z
Old Aug 29, 2025 | 07:52 AM
  #62
zray's Avatar
Originally Posted by zray
tbsts the same MAF some ebayer tried to sell me as correct for a 4.0 XKR..
not. And not correct for your XK8 either.
Z
the ad on eBay that I used was a classic bait and switch. The text / description displayed the correct Denso part number.. what I received was the MAF shown here
I believe the Denso MAF used on the 4.0 XK8’s is also used a several Mazda models. That’s what I recall reading on this forum.
Z
Old Sep 1, 2025 | 01:57 PM
  #63
stevepaa's Avatar
new MAF comes September 6.
I put old MAF back in, started car and it runs smoothly at 650 rpm
MAF reading is 24%. 1.20 V
O2 Sensors. LAM. 1.25
O2 sensor current constant at 32A
hopefully the new MAF will fix these
Old Sep 5, 2025 | 04:47 PM
  #64
stevepaa's Avatar
I ordered DENSO 197-6040
Box is noted as such, part is not
Can anyone cross reference. Usual used part has 197408-0010
Old Sep 5, 2025 | 04:58 PM
  #65
stevepaa's Avatar
Old Sep 5, 2025 | 05:16 PM
  #66
stevepaa's Avatar
https://www.kmotorshop.com/en/articl...2w93-12b579-ab
says they are same
Old Sep 5, 2025 | 06:57 PM
  #67
stevepaa's Avatar
new MAF
1.33 volts
LAM O2 sensors is 1.0
short time fuel banks both at 0%
smooth idle at 650
and no fuel smell
I will drive it tomorrow to reset monitors
Old Sep 6, 2025 | 02:26 PM
  #68
stevepaa's Avatar
smooth idle at 650, smooth driving for the drive cycle and all monitors went OK except oxygen sensor.
other issues
1) the emergency flasher stayed on after hitting the button, and I had to turn off the engine and turn back on to stop it, and now will not turn on
2) ac is not working, happened twice before this year, once because of a leak and once because the compressor clutch had worn
3) grinding noise from right front brakes as we pulled into our street after driving
I have had this car about 13 years and 30k miles. as soon as I fix current issues, I will get rid of it. it seems I cannot go a year without some issues
I had a 2002 Ferrari 575 during the same time and it had better reliability, just sold it prior to insurance rate increases
I'll likely go back to a Porsche
Old Sep 8, 2025 | 02:12 AM
  #69
zray's Avatar
Originally Posted by stevepaa
“……I have had this car about 13 years and 30k miles. as soon as I fix current issues, I will get rid of it. it seems I cannot go a year without some issues
13 years of ownership and barely 2,000 miles per year on it ? These cars don’t do well with such inactivity, and for whatever the reason for that is , your displeasure with the car is the end result.
A brief visit to the vintage Porsche forums reveals that they have numerous issues that have only become more pronounced as the years roll past. My own brother lived and breathed Porsche, and I helped him keep them roadworthy for 20 years. Until a freak accident in his 911 whale tail turbo took his life.
But I wish you the best good fortune no matter where you land next in the automotive world. Like dating a supermodel, fantastic looks are usually accompanied by high maintenance. Everyone has a different pain threshold for putting up with it.
Z
Old Sep 9, 2025 | 11:34 AM
  #70
stevepaa's Avatar
well, beside normal maintenance items like brakes, oil changes I have done the following
replaced secondary tensioners when I got it in 2012 at 78K
all coils after 10K, most misfiring
all chains and ramps at 11K, also water pump etc while I was in there
all top hydraulic lines at 13K after a leak
then new shocks all around, shock mounts and front wishbones
all after 2 years of use
engine mounts at 23k at 4 years
then at 7 year mark and 25k miles. steering rack, tank, hoses , bushes, new springs all around, front shock mounts again
then it overheated and dropped valve seat and bent valve,( that makes quite the racket ), fortunately happened in my driveway when I started it up after a trip.
It took me 2 years to get valve job done during covid, mostly waiting for a shop to open up a time slot for my head.
Also replaced radiator hoses, crossover tube, thermostat, and water pump (again)
this year the steering wheel movement cable broke, got a new cable, and needed an alignment after reinstalling steering column. I drove down to shop and then the car would idle, then stall when shop wanted to move car to stall, towed car home
fortunately I had retired at the 2 year point of ownership and had my other car to use.
also replaced top, headliner and seat covers at start of covid and now the top has cracked in three places, and the car has spent most of its time in my garage the last three years
Ashton Dimovski
Aug 28, 2025 04:56 PM
countyjag
Dec 11, 2021 06:33 AM
JohnBJag
17
Nov 18, 2014 02:24 PM
xjrwithproblems
Nov 9, 2013 02:56 PM
jkjag
Feb 7, 2012 12:01 AM
