sagging rear bumper & some parts
Old Mar 25, 2010 | 10:01 AM
JagNor's Avatar
Default sagging rear bumper & some parts
Hello!
On one side, the rear bumper is sagging a bit. There seems to be two bolts going through a bracket and into the bumper on upper side on each side. This is not by the wheels, rather on the far end of the car. There seems to be a rubber part holding the bumper to the bolt, looks like it might have let go of the bolt, it slides freely up and down. Anyone delt with the rear bumper?
Then I also need some small bits, like the plastic covers on the low sides of the seats. I know there are some inhouse parts sellers here, which one of them might haven this part?
Thanks!
Cheers, Jarle
Old Mar 25, 2010 | 10:44 AM
H20boy's Avatar
I took this directly from the Parts List pdf located in the FAQ sticky in the XK8 section. Hope it helps.
Old Mar 25, 2010 | 03:16 PM
JagNor's Avatar
I think I see what has happened. The bracket you see there, has a hole in it. And inside the hole it looks like there is a rubber guide of some sort. And it is probably fixed to the bracket. Seems like it has let go of the bracket, and just moves up and down. I think I will add some washers on top of the bracket to lift it.
Thanks!
RaceDiagnostics
Sep 7, 2015 07:28 AM
philwarner
Sep 5, 2015 10:05 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
