Sat Radio Install
Old May 13, 2008 | 03:50 PM
Mr_Miami's Avatar
Default Sat Radio Install
Anyone have any luck with a stealthy satellite radio install? Got a couple of quotes in the $200 range to install my Sirrus radio in the center console and wire it to the accessory under glove box. Don’t like the idea of broadcasting to the radio but my 97 doesn’t have an AUX on the radio and I don’t want to change the dash at all.
Old May 13, 2008 | 04:02 PM
H20boy's Avatar
Default RE: Sat Radio Install
I'm afraid without replacing the head unit, FM modulator on the sirius tuner will be the only way you can get it to work successfully. Based on the compression of the satellite radio, I doubt you will notice any huge difference in audio quality between the two possibilities. Enjoy commercial free broadcasting my friend!
Old May 13, 2008 | 05:43 PM
FactoryJaguarTech's Avatar
You can also get a cassette adapter. Hides easily when not in use.
Wire it to the cigar lighter under console. Wire taps are your friend.
Old May 14, 2008 | 10:13 AM
mlewisfwa's Avatar
Here is a link that might help for installing an "I-Pod" and I think ICRUZE make an interface for sat radio.
http://www.oemautosound.com/c-191-jaguar-to-ipod.aspx
Here is another link for some interface adapters for sat radio, didn't look hard but I didn't see one for Jag. http://www.audiooutfitter.com/satellite-radio/c512.html
I think most of these plug in where your CD player plugs in, so the cd changer won't work....
I haven't used any of these so I can't recommend them...
Good Luck....
Old May 14, 2008 | 12:58 PM
H20boy's Avatar
Yah, forgot the cassette adapter thing...I never really liked those back in the 90s. Volume levels are different (usually lower), and you have to rely on the tape deck system being clean and working well...just too many 'sources' of signal transfer for me to be comfortable with the eventual quality (unless it's talk radio you're after). It is an option, however...and a cheap one at that.
Dz1rfj
Jul 17, 2018 10:29 AM
leep123
Sep 26, 2015 04:53 PM
Dz1rfj
Sep 16, 2015 03:44 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
texaspete
Sep 10, 2015 08:34 AM
