seat belt bucklet xk8 2002
Old May 14, 2021 | 02:59 PM
socool69's Avatar
Default seat belt bucklet xk8 2002
hi
need help please
try to find a used bucklete in beige mine dont work the airbag light is one
any suggestion can help are welcom
the parts number is HJE7017AFAGD
my car dont past the security test so can drive it !!
Old May 14, 2021 | 11:32 PM
Johnken's Avatar
The part # you listed is for the female side of the seatbelt.
Friend more details in your question makes it easier to help.
Did you know that the color of the clam shell not matching is no big deal? Its just 2 pieces of plastic glued together. You neglected to say why you need replacement, what happened or why its failing. I assume you still have the old defective one? A flathead screwdriver will crack the seal. Take it off and reuse it.
Since no one's going to look at the color when testing your vehicle, why not just buy a used one, install, pass test, worry about color after?
BTW its a T41 or T40 (I 4get which) bolt holding down the seat.
Why are you failing inspection right now? Is it just the presence/absence of the female assembly?
John
Old May 15, 2021 | 12:49 AM
DavidYau's Avatar
socool69,
Welcome to the Forum. Lots of friendly folk here.
+1 to Johnken - we need alot more info on the problem to help.
From the sound of it, the female seatbelt buckle isn't working, or is it simply that the airbag light is on at the dash. Does the car say that the driver's seat belt is undone, even if it is securely clipped in. Those are all different questions with different answers. I would always go for the cheaper solutions first , by repairing what I have, before replacing things.
It could be a simple damaged electrical cable from the buckle to the module, a damaged contact within the buckle unit that is repairable, or do you need a complete replacement of the buckle unit (which will be expensive).
Old May 15, 2021 | 08:08 AM
socool69's Avatar
Yes it’s true I need to give you more information
the dash light airbag is one
the problem is the bucket seat belt driver side
this is what the code come from my garage
Old May 19, 2021 | 10:32 AM
socool69's Avatar
I think I fix it !!!
spray some contact cleaner in the bucklet and no more light fro 4 days hop it's good !!!!
Old May 19, 2021 | 01:18 PM
Johnken's Avatar
Good job!!!
Old May 21, 2021 | 09:45 AM
TropicCat's Avatar
I bought 2 from Jaguar Heaven in California for my '02. It has the Ivory interior. They are EXPENSIVE. I also have 2 used ones that work OK but the plastic is cracked and deteriorating. If you have any interest please send a PM and I'll send some pics for your review. They are a pain to replace but I can help guide you with the process.
Welcome to the club!
Old May 25, 2021 | 05:15 PM
socool69's Avatar
hi
after I started the car few time the air bag light come back on
and flash 5 time and 1 time so it's the driver seat belt buclket
any how I can clean it or need to change it ?
where I can find one ?
any one already try a chinoise one on sale on ebay
Dan
Jul 15, 2015 11:08 PM
Jagsinfl
May 30, 2013 06:23 AM
Jagsinfl
May 28, 2013 08:57 PM
rosemont83
Aug 28, 2008 09:06 PM
