seat module
Old Oct 24, 2011 | 10:04 PM
lattiepolk's Avatar
Default seat module
Need help on seat module diagnostics. Also interested in repair advise or replacement part.
Lattie
2001 xk8 62,000 miles
Old Oct 25, 2011 | 09:07 AM
test point's Avatar
The usual diagnostics on the seat module is to swap the modules between the driver and passenger seats. A common problem is that the plastic case can rub the outer circuit board line until it fails. How to on fixing it is in the FAQ sticky above.
I bought one used from car-parts.com with full matching part number and VCAT extension that worked fine. With shipping less than $100. That was on the first car.
On the present car the passenger seat stopped working and when doing the swap test I discovered that both the part number AND the VCAT number did not match. But it did work at one time. I am not sure what that tells you but my guess is that the passenger seat module is only a relay board for the switch pack on the side of the seat and does not communicate on the CAN. The driver seat, because of the communications with the seat memory module might well need to match the VCATS number.
. . . . and welcome to the forum!
Old Oct 25, 2011 | 05:18 PM
motorcarman's Avatar
Here is the Memory Systems Diagnostics TSB
bob gauff
File Type: pdf
Old Oct 25, 2011 | 08:24 PM
test point's Avatar
Bob,
Any comments on my thoughts that the passenger module need not match the driver seat module part/VCAT numbers? I still need to replace one and the initial effort did not turn up anything matching on line.
Old Oct 25, 2011 | 08:53 PM
lattiepolk's Avatar
Thank you for responses to my seat module post.
Lattie
Old Oct 26, 2011 | 10:46 AM
XKR Brian's Avatar
have repaired many. Email me if you need advise @ bambamm931@msn.com
knightofgold
Feb 11, 2016 06:03 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
multijag
Sep 14, 2015 04:54 PM
Clamdigger
Sep 12, 2015 03:43 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
