Seat module component
Old May 2, 2014 | 05:43 PM
peekaboo's Avatar
Default Seat module component
My driver seat module did not work, on my '97 XK8. So, I interverted it with the passenger module, and it is ok. Now, I'd like to fix the first module. When opening it, I saw that a component was burnt out. It fell in dust when touching it, so, it is unpossible for me to see what component it is, unless I open the working module, which I'd better avoid.
Looking at my attached pics, can anybody help me find that component's réference ? It is circled in red on my pics, and is written "RV1" on the board.
Or if somebody can have the module electronic diagram, I will like it too.
Attached Thumbnails Seat module component-seat-module-1.jpg   Seat module component-seat-module-2.jpg
Old May 2, 2014 | 09:24 PM
WhiteXKR's Avatar
It is an S14K14 Metal Oxide Varistor (surge protector) http://www.digikey.com/product-detai...4649-ND/651244
If it is blown to dust chances are there was a awful big surge that damaged other circuitry also.
Old May 2, 2014 | 10:13 PM
Steve8's Avatar
Wow.....
Surge, or long term high current draw causing a high amount of power dissipation. Could it have acted as a fusible link, perhaps a motor was left on? There's a chance the module is still workable, but I'd question what caused the draw.
Steve
Old May 3, 2014 | 05:09 AM
JagV8's Avatar
It's there to try to clip too high a voltage down to a bearable one. Should never have needed to, so something bad happened. Definitely should not have died in the process so something very bad happened. Jump started/charged carelessly? (Flashing sparks during disconnect/etc)
Old May 3, 2014 | 07:47 AM
peekaboo's Avatar
Thanks to all of you !
Your answers are very usefull.
You surely are right, something wrong must have caused the surcharge...
I'll replace the component, and see what happens. If it still does not work, I will try to find a new module.
Have a good week end.
Peekaboo
Old May 3, 2014 | 07:52 AM
WhiteXKR's Avatar
Peekaboo
This component just sits across the power rails and its function is to provide a short circuit to quench abnormally high voltages. It is purely a protective device and since it is in parallel with the circuit, its absence will not cause the module to malfunction.
Bottom line is there is something else wrong with your module, this part alone will not fix it.
Old May 3, 2014 | 10:09 AM
peekaboo's Avatar
Well, I see...
I'll show my module to a friend who is an electronics specialist.
Lawrence
XJ40 ( XJ81 )
May 9, 2023 06:31 AM
Rivguy
Nov 13, 2022 02:55 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
multijag
Sep 14, 2015 04:54 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
