seat module part #, 2005.
Old Aug 23, 2021 | 03:02 PM
wymjym's Avatar
Default seat module part #, 2005.
The seat module on 2005-2006 (USA) x100s is a different part number than earlier.
When I purchased my x100 I had (still have) weird actions + no heat. The previous owner had the unit replaced by an indy and threw away the original before discovering the strange behaviors. If I try to raise the seat bottom the left outside mirror flops in + others I forget at the moment.
I'm pulling the seats to refinish and thought it time to purchase the correct unit. Several years ago I read a thread from a fellow that had discovered the different unit was necessary after purchasing 'guarenteed' to work in his 2006, units did not in fact work. Does anyone know the part numbers for these last x100 autos?
thanks
wj
Old Aug 23, 2021 | 05:42 PM
From JEPC for the last of the XK8/XKR:
P/N LJE2160AB is NLA (No Longer Available) from Jaguar but is listed as backwards compatible for all 1997-2006 XK8/XKR:
Old Aug 23, 2021 | 07:30 PM
michaelh's Avatar
Originally Posted by wymjym
...I had (still have) weird actions + no heat. The previous owner had the unit replaced by an indy and threw away the original before discovering the strange behaviors. If I try to raise the seat bottom the left outside mirror flops in + others I forget at the moment.
Seems weird doesn't it:- but the mirror foldback is controlled by both seat modules. The foldback motors are wired in parallel so there may also be something adrift with your driver side foldback mechanism.
Try swopping the seat modules and see if the no-heat issue follows the module. They are programmable parts, and 'no heat' is one problem that can occur if the programming isn't correct for the car.
See also this thread from jagophile:
https://www.jaguarforums.com/forum/x...3/#post2245733
Old Aug 23, 2021 | 07:47 PM
RJ237's Avatar
Living in Austin I do wonder how important the heat is. My 06 had a faulty passenger module when I bought it so I bought a 98 XJ8 module and it works fine for the basic adjustments.
Old Aug 24, 2021 | 06:42 PM
wymjym's Avatar
Heat, not so much, the other aspects a lot!
Thank you Graham, much appreciated. I guess I need to plan on getting programming ability in my home garage.
Michaelh, are you saying that both l/r modules need to be operational for the mirror flop or?
wj
Old Aug 25, 2021 | 05:47 AM
michaelh's Avatar
They work in tandem to provide power to the foldback motors, so the foldback section of each seat module must be working to some degree.
omgimali
Apr 10, 2019 06:32 PM
kingcobra
Jul 21, 2017 11:12 PM
Jagboi64
Jan 10, 2016 08:43 AM
Jsnyder0828
May 2, 2015 01:18 PM
BriteRed01XKR
Aug 31, 2011 05:44 AM
