Seat motor voltage question
Old Dec 2, 2011 | 08:24 PM
ra.stewart's Avatar
Default Seat motor voltage question
Both of my seat controllers seem to be bad. I have looked over the wiring diagram and see which wires go to which motors, so I'd like to apply voltage to the motors to move the seats around to get to the bolts, etc.
My question is are the motors 12 volt? I know many things that are controlled by solid state controllers use 5 volts, but can't seem to find anything on this. I've done a search and haven't found it here, please forgive me if I have overlooked it.
Thanks in advance to all for you input!
Old Dec 2, 2011 | 08:44 PM
motorcarman's Avatar
The motors are 12V operated by relays. The feedback pots are the position sensors.
bob gauff
Old Dec 3, 2011 | 11:51 AM
JagXK82001's Avatar
Yep, these seat computers can be a real problem, easy to remove under the front of the seat, two bolts and one wiring harness.
But the cost of a new one is Jag off the charts. I think a grand or more.
I am beginning to think it would be cheaper to find and buy a parts car than attempt to replace broken parts with new dealer items. If you look at the value of a used XK you can buy it again if you have to use the dealer for a parts source.
Old Dec 3, 2011 | 07:19 PM
ra.stewart's Avatar
Great, I was hoping for 12 volt, at least I can position the seats and move them around to get them out. I'm hoping that I can repair the modules, it seems that many people have been able to solder up broken tracks.
All dealer parts are high, not just Jaguar. I needed some coolant hoses for a VW we used to own. It was a moulded set of about half inch hose about nine inches long. VW wanted $90 and I found aftermarket for $15. The friendly neighborhood BMW dealer has caused many a heart attack and my last call to the Jeep dealer ended up as $35 each for 2 inch plastic wheel center caps. I wonder if the manufacturers realize how many sales they miss due to 500% markups (or do they even care)?
Old Dec 3, 2011 | 08:31 PM
Gus's Avatar
Gus
This link might help with your electrical problem and questions http://www.jagrepair.com/images/Auto.../jagxk2001.pdf As for the repair of the seat control module I have a little information that I have not put together for a post. Let me know if you need it.
Old Dec 4, 2011 | 06:26 PM
ra.stewart's Avatar
Great, thanks, nothing beats factory info! I have access to Shopkey and find it to be pretty good, but the factory info often has the little detail stuff that others miss.
Old Dec 5, 2011 | 09:26 AM
JagXK82001's Avatar
One thing you can do if you need to put a seat in a better position is to swap the seat computer from either the drivers side or passenger side to put the seat in the correct position and then swap back to the drivers seat. A temporary fix until you can fix a seat computer or wiring problem.
I had to do that on my passenger seat since it will move rearward but not back forward. The computer had coffee get into the mix and its toast. I think the dealer wanted $800 just for the part.
Old Dec 5, 2011 | 08:58 PM
ra.stewart's Avatar
I wish I could do that, but both of mine are toast. My hope is to get the passenger seat out of the 'gangsta-lean" position and remove it's module to fix it, then pop it into the drivers seat, after I remove the drivers seat module , I'll and fix it and pop it into the pasenger so hopefully we'll get 2 funtioning seats.
Old Dec 6, 2011 | 01:53 PM
JagXK82001's Avatar
Sometimes you can find the controllers on EBay for a resonable price.
Also there is a member on this forum that works on these controlers and can do the jumper wire thingy to fix breaks in the circuit boards. Dont remember who that is but maybe you can track him down with a search. Or a post asking for assistance.
Old Dec 9, 2011 | 07:44 PM
ra.stewart's Avatar
Good news, the right module only had one bad track so I've repaired it, put it back in and adjusted the seat, then put it in the left seat. Bad news, the left module has a number of bad tracks and teh seat back recline motor or drive is not working, just a buzz. Oh well, at least I got onemodule to work so far and I can move the seat to get it out. Thanks for everyones help and suggestions.
Old Dec 9, 2011 | 08:23 PM
Car111's Avatar
The p90x workout schedule is an incredibly popular home-based, boot camp-style video exercise program that some fitness fanatics swear by. But does it do the job? A study of the system finds it does improve cardio respiratory function.
Health risks from fruit flies
Old Dec 9, 2011 | 08:52 PM
ra.stewart's Avatar
I'm trying a conductive ink pen from radio Shack on the other module, I'll post my results once I see how it goes.
Old Dec 10, 2011 | 11:32 AM
ra.stewart's Avatar
I'm happy to report that after hours of careful taping, cutting with a fresh xacto and lots of trial an error, my other control module lives! Caig labs "circuit writer", $20 from Radio Shack is a pen with conductive ink used to repair and make circuit boards. Now the question is how long it will hold up for... I think this is a viable option instead of soldering bits of wire in. Some of my breaks were so close to the chip, I was afraid to use the soldering iron.
Old Dec 10, 2011 | 11:50 AM
Gus's Avatar
Gus
Kudos to you! On the road again.
Old Dec 10, 2011 | 12:16 PM
WhiteXKR's Avatar
Nice work!
I would suggest some clear epoxy (test it first to make sure it does not make the conductive paint run) over the repairs, particularly at the edge of the board, where the case abrades the traces and causes some of the problems in the first place.
Old Dec 10, 2011 | 01:22 PM
ra.stewart's Avatar
I was thinking about that. Caig makes a cover solution, but Radio Shack doesn't sell it, so I'd have to search. I was even thinking about raiding my girlfriends clear nail polish. I put a dab of RTV silicone on the "ledge" of the corners of the cover to try and space the board away, it does not appear there are any tracks that it could harm at the corners of the board. I also put a layer of friction tape over the edge of the board on the other side. Now on to the switch troubles on the right seat and motor troubles on the left.
Old Jan 6, 2012 | 07:46 PM
dad2twins's Avatar
were you able to fix the Gangsta lean? I have the same problem.....
Old Jan 7, 2012 | 11:31 AM
ra.stewart's Avatar
Yes, by applying power to the motors I was able to get the seats in a decent position to ride in and get the modules out. The conductive ink pen from Radio Shack made fixing the modules pretty easy; I hate soldering anything with IC's or transistors, I've burnt up plenty over the years.
Broken_Spanners
Sep 6, 2015 11:34 AM
jaguarbill
Sep 5, 2015 11:43 AM
Dallas XK8
Sep 3, 2015 12:17 PM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
XJsc-guy
Sep 2, 2015 11:43 AM
