seat recline
Old Feb 10, 2018 | 10:54 AM
William James's Avatar
Default seat recline
my drivers side seat will recline but will not move towards steering wheel. Anyone else had this problem ?
Old Feb 10, 2018 | 11:16 AM
phanc60844's Avatar
switch pack or motor fault. Not sure if you can swap switch packs from side to side but give it a try, if the connector fits you can rule out the switches. After that, see if you can put 12v direct onto the motor to see if that works
Old Feb 10, 2018 | 11:36 AM
WhiteXKR's Avatar
Most of the time it is the seat controller under the seat. This is a known issue. Swap the seat controllers and see if the problem follows. Do not mess with the switches or motor unless you rule out the seat controller first.
There are numerous posts on repairing the seat controller or sending to a tech who repairs them for a very reasonable cost.
Old Feb 10, 2018 | 05:07 PM
avern1's Avatar
+1 on the seat module gone bad. Swap out the module from the passenger side and make sure the seats functions are restored. If they are contact Darrell Turner in San Diego, phone 858-649-9090. He has repaired many seat modules including mine and does a great job.
If swapping modules doesn't cure the problem get back to us and we will look at furhter options for you.
chrisant
Feb 11, 2020 03:56 PM
Sheltoncar
May 12, 2017 01:38 PM
martyXKRuk
Oct 1, 2008 05:52 PM
CJ
Mar 19, 2008 08:27 PM
Aug 17, 2007 12:17 PM
