Security on the gear shifter
Old Jul 19, 2014 | 08:05 PM
harrisgse's Avatar
Default Security on the gear shifter
I need help.
When I brought my 1998 XK* I was told there is a security system built into the gear shifter. You tap it to the left 2 times and them start the car.
I think I am having trouble with this. Sometimes the car will not start. My question and what I need help with.
Can i disable this security system?
Old Jul 19, 2014 | 09:15 PM
Jandreu's Avatar
My guess is it has to be aftermarket as I've never heard of this. So yes you should be able to remove it.
Old Jul 20, 2014 | 12:14 AM
enderle's Avatar
Default Either that or
The linkage was broken and the guy selling you the car tried to turn it into a feature. The only security on the shifter is the interlock and that should disengage when the ignition is on and the car sees the transponder in the key. You can insert the key into the little hole with the screw cover next to the shifter to bypass it if it isn't functioning (I relearned this when some nimrod moved the relays around in the trunk and it wouldn't unlatch).
Old Jul 20, 2014 | 05:26 AM
An interesting procedure.
The security system in the gearshift is the Interlock Solenoid which requires your foot on the brake pedal to release before the gearshift can be moved out of 'P'. You should be able to hear a soft click as this happens.
It sounds to me like a faulty (possibly sticking) Interlock Solenoid and the PO has found this as a workaround to avoid a proper fix.
adam699
Oct 13, 2015 05:53 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
