Seeking suggestions / tips while removing Supercharger
Old Feb 7, 2026 | 01:42 PM
Dr. D's Avatar
Default Seeking suggestions / tips while removing Supercharger
Howdy folks,
I am going to remove my supercharger / intercooler primarily in order to explore / replace hoses and gaskets for deterioration and leaks. While I am at it, I would hate to close it all back up only to learn that I did not do something that I should have added to my list.
So far, that list includes:
  • Replace knock sensors
  • Pull and force clean fuel injectors (although, I have not come along anything that suggested to do this)
  • Check bypass valve / servo operation
  • Although I am not planning to increase boost; I am replacing the intercooler pump with Bosch 0 392 022 010 from Home Depot (not a counterfeit). Also MB modified pigtail plug
  • Check SC bearings
Anything that you all can add to my list is greatly appreciated (Even if it is something that you think I would just say "I know that >>what do you think I am? A dumbbell ).
Thanks Folks
Old Feb 7, 2026 | 03:04 PM
motorcarman's Avatar
If it is the 4.0 liter I would replace the heater FEED AND RETURN hoses.
Old Feb 7, 2026 | 03:36 PM
Dr. D's Avatar
Bob,
It is a 2002 4.0L XKR conv.(Sorry, I did not think about my signature line not showing on smartphones)
I will definitely replace those valley hoses.
Just seeing your reply jogged my mind of a suggestion that you made years ago to wait till one does this project such as I am doing replace my plumbing stop leak hack (P0171, P0174) with a new proper Part Load Breather Hose Assy AJ84879
Thanks for all of your expertise
Old Feb 7, 2026 | 05:39 PM
I post this query because the 2002 MY is sometimes a 2002.5 4.2 depending on location and MY designation differences.(Europe MY confusion)
There is still a hose under the 4.2 that needs to be addressed.
Old Feb 8, 2026 | 12:15 PM
Hickman56's Avatar
I did mine last year. I would recommend replacing both fuel rail dampers. Common leak point. Mine was leaking (the cause of my repair). I sent all of my injectors to a company called Injector Planet (Florida). They cleaned them, flow tested, replaced the O-rings, and supplied the fuel dampers for $50 each. The injectors and dampers are Ford parts. I also replaced the valley hoses and the octopus hose. Note: you do not have to replace the octopus has while the supercharger is off. After the fact, you can get to it all if necessary later when the supercharger is on. Also change the supercharger fluid while it is off. Much easier than when it is in place. I also replaced both serpentine belts, water pump, and stat. Reassembly hint. When installing the coolant crossover on the front of the engine, replace the spring clamp for a screw style on the 3/4 valley hose. It will make install and tightening somewhat easier from the top. You can thank me latter.
Chopper
Dec 31, 2025 12:22 AM
LausDeMaus
Sep 5, 2022 07:25 AM
aquifer
May 27, 2022 05:46 AM
seawind
Nov 25, 2014 09:22 PM
fergs03R
Apr 12, 2013 01:09 PM
