Seen Oil By overhead reading light button
Old Aug 12, 2015 | 01:17 PM
bcucharternet's Avatar
Default Seen Oil By overhead reading light button
I have a 2000 xk8 convertible and noticed a small amount of oil on my overhead reading light button. The hydraulic line for the top was replaced 4 years ago at a Jaguar dealership and I have not used the top since July 24th. I live in GA and it has been very hot this summer.
The only thing I did was to lower and raise the rear windows.
Is there an easy way to get a look at the connection? Does anyone have any ideas of why this may have just happened.
Thank you
Brian
Old Aug 12, 2015 | 01:57 PM
WhiteXKR's Avatar
It could be nothing more than old oil that has migrated that was not cleaned up from the previous episode 4 years ago....or....you could have another leak. It could be the hoses or the hydraulic actuator. It probably would be a good idea to inspect them, as well as the level in the pump tank.
Old Aug 12, 2015 | 02:31 PM
Default How to remove overhead reading light cover.
What is the best way to inspect the hose and fitting? Do you remove the overhead reading light cover and if so how do you remove the plastic assembly?
Brian
Old Aug 12, 2015 | 03:59 PM
Gus's Avatar
Gus
You may need a small mirror and light to see the problem but you will need to remove the plate where the roof latch is located. Use this link and go down to the 10th & 11th photo.
Old Aug 12, 2015 | 05:32 PM
Default Fitting Replacement Kit
Thank you the pics are great. I will pull tomorrow and see what I can see. Is there a replacement kit that you can replace just the fittings if they are leaking since the hose was replaced only 4 years ago?
Brian
Old Aug 12, 2015 | 06:58 PM
test point's Avatar
Sorry, no. The entire hose, and you should do both if only one is leaking, must be replaced. Jaguar tried splicing and that didn't work.
Too much time in the Georgia sun. Hose failures are not common in the mother country because the sun never shines. You are ahead of the game by living in sunny Georgia even with sun damaged hose problems.
Old Aug 13, 2015 | 07:27 AM
Default Oil drip at Overhead reading lights
I pulled the top cover, thank you again for the pics, very helpful!! The hoses and the area around and under the two hoses are bone dry. The only place I can see any oil, very very little, is directly under the hook that pulls the top closed. Everywhere else is completely dry, including between the block the hoses go in to and the hook.
I have not used my top in over three weeks, I just used the door key twice to lower the rear windows and then the top up/down button on the console to close them. I saw oil on my reading light on/off button the day after I did that the second time.
Thanks again
Brian
Old Aug 13, 2015 | 07:40 AM
WhiteXKR's Avatar
Also check the pump reservoir for the correct level, between the two embossed lines on the clear tank. The pump is over the CD changer in the trunk (pull away the carpet).
Old Aug 13, 2015 | 07:43 AM
RJ237's Avatar
Thanks again
Brian
They probably didn't replace the latch. If that's what leaking you can have it rebuilt by Top Hydraulics.
Old Aug 13, 2015 | 08:15 AM
Default Reservoir Oil Level
The oil level is maybe 1/16" below the bottom line on the top pump.
Brian
Old Aug 13, 2015 | 09:15 AM
Gus's Avatar
Gus
Fill it to the top line.
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
