Sensors
Old Jun 4, 2020 | 09:56 PM
Syb Drylst's Avatar
Default Sensors
Hi y'all,
Does any one know what are the 2 sensors onder the manifold intake of a 1997 jag XK8.
Thanks ahead.
Old Jun 4, 2020 | 11:48 PM
giandanielxk8's Avatar
Originally Posted by Syb Drylst
Hi y'all,
Thanks ahead.
Knock sensors
Old Jun 4, 2020 | 11:53 PM
DavidYau's Avatar
Default Probably referring to the knock sensors
Syb,
You’re probably referring to the knock sensors.
Really need to know where exactly you’re referring. A picture would help.
Old Jun 5, 2020 | 03:15 AM
Does this help?
Old Jun 5, 2020 | 11:39 PM
Syb Drylst's Avatar
Yes that's the one,thanks for the illustration. Ihave a engine code stated its a knock censor, so what is the function of a knock censor .
Thanks for your help.
Old Jun 5, 2020 | 11:42 PM
Syb Drylst's Avatar
Thanks David,
Graham send me a drawing which shows where the sensor are.
Old Jun 5, 2020 | 11:45 PM
Syb Drylst's Avatar
Originally Posted by GGG
Does this help?
Old Jun 5, 2020 | 11:46 PM
Syb Drylst's Avatar
Originally Posted by DavidYau
Syb,
Thanks David,
Old Jun 6, 2020 | 12:42 AM
DavidYau's Avatar
Default What is a knock sensor
It’s function is to detect irregular detonation in the piston combustion. The sensor sends signals depending on engine vibrations, and the ECM can make adjustments to stop this “knock.”
Car will be driveable but fairly important to move on this as there’s a small risk of severe engine damage if left too long.
Syb
Jun 7, 2020 10:17 PM
yachtmanbuttson
Feb 5, 2020 07:37 AM
karissatx
Aug 26, 2018 10:04 PM
Gus
Jun 23, 2013 02:06 PM
The Coupe
Feb 27, 2012 10:43 AM
