Shock bolt making noise
Old May 15, 2013 | 01:46 PM
randyb's Avatar
Default Shock bolt making noise
every little bump, I get clatter from the bolt holding the shock on, hits the shock mount. started right after I changed the shocks and shock mounts.
Old May 15, 2013 | 02:51 PM
GordoCatCar's Avatar
Front or rear?
You said you changed shocks? New shocks w/ new bushings?
Not sure what you mean by shock mount?
Old May 15, 2013 | 03:08 PM
randyb's Avatar
front shocks and mounts were replaced.
when I go over a bump, sounds like shock piston is pushing the bolt off the mount and the makes a clattering sound when bolt/washer hit back down on the shock mount.
Old May 15, 2013 | 04:29 PM
RaceDiagnostics's Avatar
The bolt should be snug in the bush sleeve ie no movement and it then should be torqued up to about 80Nm (check JTIS) so it should not move within the lower arm mount.
Check how tight your bolt is.
Old May 16, 2013 | 12:15 PM
randyb's Avatar
Was wondering if I maybe did not tighten the bolt down enough.
Rivguy
Dec 4, 2020 07:55 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
philwarner
Sep 5, 2015 10:05 AM
Busa R
Sep 3, 2015 05:01 PM
