Shock Bushings
the rebuild kit works very well. did mine about 3 months ago...also you may want to replace the shocks and the uper control arm bushings while at it and things are apart . am sure the lower shock bushings will be trashed . also make sure when reasembling the shock mounts you hold the top of the shock bolt while tightening the nut i didnt and had a very annoying rattle till i tightened it that way on the car which i believe is much harder .
Gus, these are the one's I saw on Ebay UK...
Jaguar XK8 XKR Lower Front Shock Absorber Bush | eBay
Wayne
Wayne
The reason I am asking is that my search revealed a WIDE swing in price and the parts package. My inspection of the lower bushings look good but the top is clearly worn and the nose is a little low.
Consider the rebuild kit instead.
if needed the lower shock bushing is available here try welsh enterprises they show them for 46 dollars .Welsh Enterprises, Inc - Jaguar XK8 / XKR (97-06) Front Suspension Parts
part # MJA2153AB i believe
I wasn't an aftermarket one either ...
Was able to fix things after two go-rounds. Turns out my old top bushings were not rusted so I drilled out the rivets and reused the plate with the old studs. The reason for the second go-round was that I reinstalled the inner bushing upside down (the washers are different from top to bottom) and didn't notice it until it was time to torque the center shock nut.
Oh well, I'm getting very quick at using spring compressors.
Lesson learned - if the plates aren't rusty, the rebuild kit is the way to go.
Low noses must be contagious right now ...
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
