should I install eccentric bolts while replacing ...
Old Jun 2, 2014 | 07:28 PM
jonscot's Avatar
Default should I install eccentric bolts while replacing ...
Gearing up for a complete bushing overhaul / shock mount / ball joints ( basically all the easy bits that rub together ) for my 2000 XK8 - and I read about an eccentric bolt that was sometimes used for alignment ... and I have no clue if this car has them.
( The car tracks perfectly now, and has nice tire wear patterns. )
Since I'm all up underneath her anyway, should I just order some and do the replacement?
Last edited by jonscot; Jun 2, 2014 at 08:08 PM. Reason: make my sentence more clear
Old Jun 2, 2014 | 08:03 PM
djhaydel's Avatar
The eccentric bolts are in the carriers/wishbone assemblies not in the shock bushings from my knowledge and past experience. Just recently change the upper front bushings (05MY XK8) and there are no eccentric bolts in that assembly.
Old Jun 6, 2014 | 09:30 AM
Lifts's Avatar
absolutely. With out replacing there is no adjustment on thelower control arms
JarodL
Mar 7, 2024 01:39 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
Dallas XK8
Sep 3, 2015 12:17 PM
