Silverstone vs XKR 100
Old Nov 24, 2010 | 07:19 AM
flyiad's Avatar
Default Silverstone vs XKR 100
Morning All:
I am trying best I can to become educated regarding a hopefully forthcoming purchase; either a Silverstone or 100 Convertible. Am I correct in that the primary differences between the two would be the seats (Recaro in in the 100), and Xenon lights (in the Silverstone)?
Any feedback the board could provide would certainly be appreciated.
Cheers!
Chuck
Old Nov 24, 2010 | 12:10 PM
Sean B's Avatar
The 100 has the updates to the engine, it should have xenons also. You need to post this in the XK/XKR forum.
Old Nov 25, 2010 | 12:46 AM
H20boy's Avatar
transport complete captain!
Old Nov 25, 2010 | 06:57 AM
flyiad's Avatar
Thanks Sean- I see that it does have the Xenon's, appreciate the input
Old Nov 25, 2010 | 06:19 PM
RCSign's Avatar
Chuck
They are basically the same car except early model Silverstones had the Nikasil engines where the X100's would be steel lined. If the Nikasil engine has made it this long without problems it probably OK. One of the reasons was sulfated gas that was used in the late 1990's and 2000 I have a Silverstone with a build date of Aug 2000, Nikasil lined block, and it runs superbly with 80,000 on it. The plastic tensioners where changed to the third generation steel in Aug of 2001, but you have to go by the serial # of the block not the car. The XKR's will keep a big smile on your face whenever you drive it.
Doug
2001 XKR Silverstone
Old Nov 26, 2010 | 07:09 AM
flyiad's Avatar
Thanks Doug- also getting up to speed on the tensioner and hydraulic top issues, I appreciate the input greatly.
duecedriver
Dec 25, 2015 11:47 AM
John Fox
Sep 19, 2015 07:56 PM
hhv00586
Sep 18, 2015 08:59 AM
Tim Goz
Sep 17, 2015 09:11 AM
powerhouse
Sep 9, 2015 08:08 PM
