Slow moving rook
Old May 6, 2017 | 05:49 PM
Dontknowanything's Avatar
Default Slow moving rook
The roof will open and close only with some help from me, that is, I need to manually push it open or close. Also moves slowly when it starts opening and closing. Any suggestions on what is going on? P.s. I did get a new battery thinking that would solve the problem - not!
Old May 6, 2017 | 05:57 PM
dsd's Avatar
dsd
How much fluid and what color is in the hydraulic tank (its in the boot near the stereo gear on the right side).
Any leaks (like green fluid anywhere)?
Old May 6, 2017 | 07:21 PM
RJ237's Avatar
It would help if we knew what year the car is and how many miles. If the reservoir has green fluid but the level is low check for fluid in front of the rear wheels at the bottom of the rocker panel.
Old May 6, 2017 | 11:18 PM
avern1's Avatar
Definitely check the fluid and if low check the main rams leaking. While you are in there checking the fluid make sure the bypass valve is fully closed. The valve is a mall rod with a T-type handle on the pump. If it isn't full closed clockwise it will bypass pressure when the pump is operating.
Old May 7, 2017 | 06:37 AM
Anthony8858's Avatar
In case the OP ever comes back.....
https://www.jaguarforums.com/forum/x...refill-179953/
Old May 7, 2017 | 09:51 AM
Johnken's Avatar
Btw, I wondered about speed to close when I got mine. Folks on this site taught me that specs call for it to open or close within 20 seconds of pushing the button. I typically see a count of 15.
John
Old May 7, 2017 | 10:14 AM
Originally Posted by Dontknowanything
The roof will open and close only with some help from me .....
Welcome to the forum Dontknowanything,
JaguarVDP
111
Jun 14, 2018 10:02 AM
Tel
Oct 19, 2016 02:11 PM
slojotaa
F-Pace (X761) / C-X17
Oct 16, 2016 12:50 PM
Jeff DeVere
Oct 13, 2016 07:00 AM
MikeofBonsall
Oct 1, 2016 06:15 PM
