So here's a valet key question
Old Apr 10, 2015 | 05:55 PM
marvin.d.miller's Avatar
Talking So here's a valet key question
I don't have my valet key. It was lost to history some years ago before I acquired my kitty (99 XK8). I'm curious, what would happen if I were to push the valet button without a valet key? Would I be locked out of my trunk and glove box forever?
Old Apr 10, 2015 | 06:15 PM
Jandreu's Avatar
Nope the regular keys always work.
Old Apr 11, 2015 | 12:58 AM
Johnken's Avatar
Don't forget, the valet key (green) can not open the trunk, or I believe a locked glove compartment. The valet button disables the trunk release button on the dash board, so the premise is if you don't want a driver (valet for example) to get in your trunk, you hand him/her the green valet key, press the valet button and keep the black normal key and the remote transmitter. That way they have no way into the trunk without a sledgehammer.
Old Apr 11, 2015 | 03:21 AM
After pressing the Valet button, the vehicle can be started or locked with the green headed Valet Key but the luggage compartment and glove box can ONLY be opened with a black headed Master Key.
Using the Master Key or the Remote cancels the Valet setting.
Old Apr 11, 2015 | 05:18 PM
mrplow58's Avatar
If you compare a valet key very carefully to a regular key, there are some very small differences in the cut. I am not sure if a transponder is used, but a locksmith friend showed me the differences.....Mike
Old Apr 11, 2015 | 05:28 PM
Originally Posted by mrplow58
......... I am not sure if a transponder is used, but a locksmith friend showed me the differences.....Mike
Both Master and Valet Keys have a transponder chip embedded in the plastic head.
The difference between a Master (black) and a Valet (green) is only in the section marked in red. The blue sections are identical:
The Master red section is smaller diameter than the Valet. A Valet key can be converted into a Master but not the other way round.
Old Apr 11, 2015 | 05:35 PM
The transponder chip is under the cover flap circled in red:
Difficult to photograph!
Old Apr 11, 2015 | 05:45 PM
Here's a fuzzy pic of a transponder on it's way out of the valet key.
philwarner
Oct 4, 2024 01:37 PM
XJsc-guy
Nov 23, 2015 01:56 PM
speacock
Sep 10, 2015 12:14 AM
tberg
Sep 7, 2015 07:32 AM
My Pham
Sep 4, 2015 03:37 PM
