Someone Backed into me!
Old Feb 5, 2016 | 09:22 PM
KayScotts's Avatar
Default Someone Backed into me!
Hey guys, so today I get home after work to find my Aunt backed into my XK8. As far as I can see, all that was damaged was the right headlight housing has been completely shattered. What my question is, what is the small half-circle piece that's supposed to be under the headlight housing?(circled in picture) I bought the car with it missing on both sides and figured if the one side is going to be getting completely replaced then I might as well replace the left headlight myself as well so it doesn't look obvious that the small piece is only missing on the left side.
Thanks in advance!
Old Feb 5, 2016 | 09:27 PM
Johnken's Avatar
[QUOTE=KayScotts;1397245]Hey guys, so today I get home after work to find my Aunt backed into my XK8. As far as I can see, all that was damaged was the right headlight housing has been completely shattered. What my question is, what is the small half-circle piece that's supposed to be under the headlight housing?
Looks like my headlight washer.
Old Feb 5, 2016 | 09:40 PM
KayScotts's Avatar
Great, just googled it, that's exactly what I was talking about thanks!
Old Feb 6, 2016 | 04:35 AM
jamdmyers's Avatar
If you don't have the Washer feature there is a 'Plastic' filler piece in that area, check you vin / features
Old Feb 6, 2016 | 04:38 PM
SeismicGuy's Avatar
Yeah--what's missing is the trim cap over the powerwasher. I went through replacing on a year or so ago and you can search for my thread. I am attaching a few pics from my experience and it is likely that if you would need to replace the powerwashers if you want the trim pieces to stay on while having functional washers. If you don't care about the wash feature you can just get the trim pieces (about $35 if I recall correctly) and just glue them in.
Doug
Attached Thumbnails Someone Backed into me!-closeupnozzle.jpg   Someone Backed into me!-separatedpieces.jpg
Old Feb 7, 2016 | 09:14 PM
KayScotts's Avatar
Doug
This'll be a huge help, thanks! I think I'm just going to get cover pieces like you mentioned rather than replace the whole washer set up because the washers look like they've been completely disabled from the previous owner (one appears mangled and covered in some sort of adhesive and the other isn't even there anymore?)
Old Feb 7, 2016 | 10:51 PM
SeismicGuy's Avatar
The cover you need is secured to the nozzle by some stupid plastic (of course) fitting. So it sounds like the previous owner found that the fitting had broken so they just glued the cover to what was left of the nozzle and then disabled the washer. I try to keep things as original as possible with my cars so I went through the expense of replacing the powerwash contraption along with the cover (which had gone missing). The actual piece you need is:
Jaguar XK8 1997 2004 Headlamp Washer Jet Cover Friver Side LJA7055FA OE New | eBay
I have been buying parts from one of the sponsors here--SNG Barratt. They have good prices for forum members and will get you the part quickly.
Doug
Ungn
May 24, 2016 05:15 PM
danielhux
May 14, 2016 09:10 PM
jagtoes
Mar 18, 2016 06:24 AM
Eurobahn Jaguar
VENDOR Threads
Jan 18, 2016 03:57 PM
stingray71
Jan 15, 2016 02:07 PM
