Spark Plug for Early XK8
Old Feb 26, 2015 | 01:17 PM
Madbrad's Avatar
Default Spark Plug for Early XK8
Just when I thought I was getting to know my car, I learn something new. My car was manufactured in 3/97. According to an old thread about spark plugs, my engine is an AJ 26, not 27 and I should use NGK BKR6 vs. what is shown on parts websites as BKR5 series plugs, at least when referring to iridium plugs.
So do the parts sites have it wrong?
Thanks!
Old Feb 26, 2015 | 01:43 PM
gatekeeper's Avatar
The sites may have it wrong, but it is a very small difference. The 5 is in a lower heat range than the 6. What are the plugs in your car now? If they have served you well stay with them. If not take your pick between the two you posted, either will work, and run them for awhile (800-1000 miles) and see how they look after that. Here is a link to a PDF for NGK plugs. http://www.ngksparkplugs.com/docs/te...bols_plugs.pdf
Old Feb 26, 2015 | 01:52 PM
Madbrad's Avatar
Thanks Gatekeeper. I would presume that the original plugs are in the car because it has only 57K. In other words, they are whatever was installed by the factory. I have not pulled them yet. They are not "due" to be changed before 100K, but I thought I might change them at the upcoming 60K, just because of their age.
Old Feb 26, 2015 | 02:24 PM
Gus's Avatar
Gus
I have used Bosch for years in both my Jags with no ill affects. The plug I have been using is Bosch Platinum 4 or Double. Unless you have an XKR your XK8 will run just fine.
Old Feb 26, 2015 | 02:30 PM
Madbrad's Avatar
Thanks Gus. Is this the part? I note that the gap is preset. Is it preset to.052?
BOSCH Part # 4418 PLATINUM+4
Old Feb 26, 2015 | 02:48 PM
Gus's Avatar
Gus
I never had a reason to test them when you see a "4" you will know what i mean.
Old Feb 26, 2015 | 03:34 PM
Madbrad's Avatar
Thanks Gus. I have a feeling that I asked a dumb question with regard to the "4". Are they good for 100k like the originals?
Old Feb 26, 2015 | 04:00 PM
Gus's Avatar
Gus
I ran them for around 65/70 k. Not hard to change so I changed them no real reason.
Old Feb 26, 2015 | 04:08 PM
Madbrad's Avatar
Thanks again Gus. Having now seen a picture of the 4's, I can why no gapping. I'll give them a try. Right now I'm having a devil of a time sourcing the AJ26 cam/spark plug seals. No use starting the spark plug project until I have those.
Old Feb 26, 2015 | 04:12 PM
DaveInVA's Avatar
As you have an early one like mine (11/96) you will likely need the ones like this
I need to change mine as my car has 98k miles and I have no idea if they have ever been changed as yet.
Dave
Old Feb 26, 2015 | 04:19 PM
Madbrad's Avatar
Thanks Dave. I also found them at FCP Euro.
https://www.fcpeuro.com/products/jag...-xjr-nca2578bb
Old Feb 26, 2015 | 04:27 PM
plums's Avatar
I'm not keen on the Bosch and see no reason to move away from NGK.
Within the NGK offererings, you can move around on heatrange and materials type.
I use the Platinum since I am not expecting plugs to last 100K.
cissdm
May 3, 2016 06:02 AM
caveforce
38
Nov 16, 2015 10:19 AM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
Bowman
Sep 3, 2015 03:17 PM
