Spring inside ABS ring?
Old Jun 10, 2023 | 10:34 PM
Stamford's Avatar
Default Spring inside ABS ring?
I see there is a curved flat spring that sits down in the center of the ABS ring. Can anyone explain its purpose? Doesn't appear to be doing anything.
Old Jun 10, 2023 | 11:05 PM
baxtor's Avatar
Are you referring to the spring pin nut lock on front?
If so it should be engaged through axle and into slot on reluctor/nut.
Old Jun 11, 2023 | 12:27 AM
Pistnbroke's Avatar
A picture is worth a thousand words.
Old Jun 11, 2023 | 09:43 AM
xalty's Avatar
to stop you from inserting the tool
Old Jun 12, 2023 | 11:39 PM
Johnken's Avatar
Do you mean the cir clip inside the hub above the speed sensor disk? If so, i believe it holds the abs ring in place. Though given how thats screwed in i can't imagine it just loosening.
Ah its been a few years, I'm having trouble remembering what else it could be wrt the bearing sorry.
John
Old Jun 14, 2023 | 04:51 PM
Stamford's Avatar
Ah, on closer inspection I see the spring clip has the holding pins attached to its ends. Does seem superfluous, as I also can't imagine the ABS ring coming loose, given what a job it is to remove it. Thanks for the input!
Old Jun 14, 2023 | 05:01 PM
baxtor's Avatar
Yes, unlikely but a fun ride if it did.
RichardAES
Mar 15, 2023 04:43 PM
Dukejag
Nov 9, 2021 12:36 AM
dan02xk8
Apr 25, 2014 12:06 PM
mascari5
Dec 21, 2010 08:55 AM
MTZGR777
Mar 27, 2010 01:36 AM
