Squeaky belts
Old May 15, 2013 | 04:45 PM
Seakiwi's Avatar
Default Squeaky belts
On startup I have an annoying squeak from the belts that lasts about 10 to 15 minutes and then is gone for the day.
I am having trouble getting it tracked down as it is gone before I can isolate it and never there when the car is in for service.
Known issue? Any ideas for a non mechanically minded owner?
Old May 15, 2013 | 05:17 PM
Any chance that coolant has been splashed on the belts?
If so, it seems to put a 'glaze' on them causing a squeak on startup. The only solution is replacement.
Old May 15, 2013 | 05:23 PM
Seakiwi's Avatar
Anything's possible with service techs Graham
Also found this thread:
https://www.jaguarforums.com/forum/x...g-44242/page2/
Old May 15, 2013 | 07:42 PM
ccfulton's Avatar
I've seen a few tricks to quiet squeaky belts that *sometimes* work.
1) Belt treatment spray: A little might help, too much will probably make it A LOT worse.
2) Scotch Brite: When you start the car after sitting over night and it's squealing, take a square of the course scotch brite and touch it against the belt while the car is idling. If the belt isn't too far gone, this can remove some of the glazing and roughen the surface enough to stop the squeak.
I've tried #2 and it works, but be careful you don't lose your fingers in the process.
Old May 15, 2013 | 10:13 PM
Jag#4's Avatar
Had the squeaky belt several months ago. The belt treatment spray worked for me, but needed touch up after about 30 days.
The next time it happened, I changed the belt. On the NA model, there is only one. Belt was about $45 and it maybe took 15 minutes. Most of that time was checking the belt diagram to make sure I was threading it right. Easy job.
Old May 15, 2013 | 10:36 PM
tberg's Avatar
Mine chirp like crickets for the first startup of the day, lasts like you about 10-15 minutes and then gone. It has been doing this since the first day I owned the car, 3+ years and 60K miles ago.
Old May 16, 2013 | 05:17 AM
JagTheRipper's Avatar
Have a look at this thread too: https://www.jaguarforums.com/forum/x...er-belt-95411/
Old May 16, 2013 | 09:55 AM
Jochem00's Avatar
have you changed your belts yet?
especially the accessoiries belt.
it's only about 20 dollars. Take the goodyear one and all should be quite again
Old May 16, 2013 | 05:14 PM
Seakiwi's Avatar
Thanks guys, new belts for me and a check to see if the pulley/tensioner fix is required
Garry
MrWhite
19
Jun 14, 2022 07:49 PM
04Xjrsteve
May 7, 2019 04:06 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
42Ajd
Sep 26, 2015 07:04 PM
