Squeeling when cold
Old Jun 6, 2016 | 10:25 AM
looops's Avatar
Default Squeeling when cold
Hi all.
Just bought a lovely XKR but when cold there's a squeal from the belts. Is it likely just a pair of belts or something more sinister?
Thanks.
Old Jun 6, 2016 | 10:51 AM
RJ237's Avatar
It could also be idler or tensioner pulley, even harmonic balancer, water pump, alternator. A stethoscope is handy for locating the source. Also try removing the SC belt to eliminate that system.
Old Jun 6, 2016 | 10:52 AM
The usual cause is a 'glazed' belt which has had coolant spilled on it but it could be a failing belt spring tensioner.
Old Jun 6, 2016 | 12:17 PM
marvin.d.miller's Avatar
Go to the auto parts store in your neighborhood and get a spray can of belt dressing. Start the car and give the belt a one second squirt where it leads into a pully. if the squealing doesn't stop...it's not the belt
Old Jun 6, 2016 | 01:19 PM
stingray71's Avatar
I agree. The belt tensioner may have lost its tension/spring that keeps the belt tight. If the pulley bearings are going bad, this is easily identified with a mechanic's stethoscope (fairly inexpensive in the auto parts store). You should hear a definite difference between the bad pulley and the others when listening with it. It will have a grinding/rumble sound.
Old Jun 7, 2016 | 04:01 AM
looops's Avatar
Thanks all. I used a stethoscope and all is quiet except for the power steeering pump. I have to change the tensioners so while I'm in there I'll change all pulleys, waterpump and belts.
Old Jun 7, 2016 | 11:23 AM
Johnken's Avatar
+1 on idler. Release belt tension rotate pulley by hand. If not smooth as silk -you found it.
JessN16
Jan 6, 2017 11:03 AM
DrDSP
Jun 23, 2016 11:12 PM
scubayachts
Jun 12, 2016 11:50 AM
YYC guy
May 23, 2016 06:34 PM
Michaelson0101
May 10, 2016 01:12 PM
