SRS/Airbag codes
Old Jul 12, 2010 | 04:15 PM
Onca3's Avatar
Lightbulb SRS/Airbag codes
Pulled this data from the DTC B-codes and sorted.
XK SRS/Airbag Codes
(Number indicates number of blinks, for instance, 13 is seen as a single flash followed by a pause, then three successive flashes, often repeated several times)
13 - Crash data memory full
16 - Pass seat weight sensor CAN fault
17 - Pass spatial sensor CAN fault
18 - Pass airbag deactivate lamp circuit fault
19 - Airbag circuit status fault – driver
21 - Airbag circuit status fault – pass
22 - Side Airbag circuit fault – driver
23 - Side Airbag circuit fault – pass
33 - Seat Belt Pretension fault – driver
34 - Seat Belt Pretension fault – pass
42 - Impact sensor circuit fault – front
43 - Impact sensor circuit fault – driver side
44 - Impact sensor circuit fault – pass side
51 - Seat belt switch circuit fault – driver
52 - Seat belt switch circuit fault – pass
53 - Airbag audible warning circuit fault
54 - RCM configuration failure
Old Jul 12, 2010 | 04:31 PM
H20boy's Avatar
Great find, I was always wondering what these meant. I cleaned it up a bit, and will add it to the FAQ section.
Old Jul 12, 2010 | 04:33 PM
Onca3's Avatar
Thanks for the clean up -- looked good on my screen until I did the submit.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
