Stability Control Fail (ABS)
Old May 26, 2011 | 08:31 PM
mutaG3N SRT's Avatar
Default Stability Control Fail (ABS)
Hey, I replaced the lower control arm bushings and the ABS light came up, not sure if the ABS it's working because I drive the Jag like an old lady but the Stability Control Failure it's on all the time and won't let me see the computer info unless I hit the button and then goes back to the SCF display which I hate. Before I get down there to see what's up with it, wondering if this happened to anybody in here. I'm pretty neat when playing mechanic so I doubt that I left the ABS Sensor unplugged.
Thanks.
Old May 26, 2011 | 09:07 PM
Reverend Sam's Avatar
You should at least check the connections. Unplug and plug in the connectors a couple of times. Also check how you routed the wires. If the wire wasn't routed correctly it might be pulling out of the connector when you turn the wheel.
Old May 27, 2011 | 12:34 AM
Yeah, I pretty much figure it's the connection, we all know that this kitties love connection FAIL!
ericjansen
Dec 19, 2021 12:20 AM
skyryder
Mar 25, 2016 08:18 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
jaguarbill
Sep 5, 2015 11:43 AM
