Stability Control Failure
Old Nov 4, 2011 | 11:10 AM
JagManBonano's Avatar
Default Stability Control Failure
Stability control failure. What should I do to diagnose the problem? Any ideas of what it could be?
Old Nov 8, 2013 | 12:31 AM
zagumsuail's Avatar
Default on my jags which are 98 xk8 and 99xj8l and 2000 xj8 whenever stability control fail
I just remove the abs connector` I spray with little bit wd40 `let dry before connect ` connect the battery and voila ! stability control fail lite goes away
Old Nov 8, 2013 | 06:02 AM
RJ237's Avatar
Is your abs light on also? Here is some info from jagrepair.com to get you started:
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
There is a lot more available there. One thing to note: The resistance of the sensors is usually 1000- 1040 ohm. If the sensors and harnesses check out it is probably the solder connections to the abs pump. This is a diy, or you can send it to various repair services found on ebay.
Old Nov 8, 2013 | 07:05 AM
philhef's Avatar
Mine did it from time to time as well. Usually when I am in reverse turning out of a parking space. It's one of my front wheel sensors and when we had the springs changed, I stopped by and cleaned the sensors and it hasn't happened since.
Old Nov 8, 2013 | 01:09 PM
pophen's Avatar
This happens to me a few times each year, usually after a tire/wheel wash or driving through a deep puddle. Light goes on for the most 3 starts then it's fine. Going to remove sensor and clean soon. Jack
Old Feb 12, 2020 | 09:49 AM
Fred Pearl's Avatar
Cool
Where is the ABS connector found?
Avg Joe
Old Feb 12, 2020 | 10:14 AM
bladerunner919's Avatar
Avg Joe
On the ABS module, next to where the screenwash goes in.
Old Feb 12, 2020 | 02:07 PM
RJ237's Avatar
Avg Joe
Welcome to the forum. If you are having ABS problems please start a new thread instead of tacking on to one that is several years old, and include the year and model of your car.
If you haven't already done so, please visit the new member area and introduce yourself. Link:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
bdboyle
Sep 16, 2019 05:58 PM
ryan_border
Dec 23, 2015 04:27 PM
zdrapec
Sep 25, 2015 05:49 AM
mrplow58
Sep 24, 2015 08:05 PM
mrobinson
Sep 18, 2015 07:20 AM
