Standard Oil or transmission cooler XKR
Old Jan 5, 2022 | 05:46 PM
Markmbaha1's Avatar
Default Standard Oil or transmission cooler XKR
I noticed an extra small radiator on the front of my 2004 XKR then remembered something hit botom when backing out of the driveway the other day. My xk8 did not have that. Do the XKR have a standard extra oil or transmission cooler like this?
Thank you.
Old Jan 5, 2022 | 07:12 PM
motorcarman's Avatar
Engine oil cooler.
Old Jan 5, 2022 | 07:26 PM
Markmbaha1's Avatar
Engine oil cooler.
With it that low in afraid of hitting it over the curb. Any thoughts?
Old Jan 5, 2022 | 09:41 PM
zray's Avatar
one must take care when parking. Don’t make it a practice of pulling forward until the tires hit the curb. Most curbs can clear the car, but some won’t.
It doesn’t take that much practice to get it right every time
Z
Old Jan 6, 2022 | 07:02 AM
JayJagJay's Avatar
I think folks have figured out a remount - if you search threads here. I usually use a Google search with right key words, then, see what comes up,,, then, click the little tab that says, "show more results" or some such other.
If you get under the front of the car, no jacks or nothing, just to look, you'll be able to see how it's mounted and what's possible... ALSO, as suggested, get used to a car that rides as low (and other characteristics) just takes a bit O time
Old Jan 6, 2022 | 07:05 AM
JayJagJay's Avatar
Try this thread. May be the thing.
Old Jan 7, 2022 | 07:28 AM
Markmbaha1's Avatar
Thank you. My Corvettes were lower and had an air scoop down there, but this oil cooler down there is asinine. Hopefully I can get under today and make the bracket change discussed. Thanks
pauledddy
May 3, 2019 11:15 AM
powerhouse
Apr 21, 2017 03:34 PM
Ghostrider
Apr 14, 2017 07:39 PM
jagxkrtoofast
May 19, 2012 09:22 AM
Grendel
Sep 29, 2010 04:00 PM
